Thread: Need to stop just throwing money around randomly.. [FILTER]
    So.. 15,000ish gallon Above ground, I have a 1hp pump and a 16" Hayward sand filter. The filter has been fine for the 2 previous years, but this year I ran into quite an issue with particles that it could not filter. Sadly it came to I had to floc the pool.. and am still dealing with getting the gunk off the bottom out to waste. So my question comes to this.
    I have to spend some money coming up soon. There's a possibility that my multiport valve is having an issue (possibly causing the filter to not work as well?) - it leaks water to waste when put on recirculate. Is that enough of a problem to cause a filtration issue? I don't know - maybe - can't tell. So there's $75 bucks I could spend as just a shot in the dark.
    If I continue to waste this flocc-ed stuff, I'm going to end up needing a $265 truck of water (well can't possibly keep up)
    Seems a sand filter isn't really the way to go, and the one I bought at 16" is too small anyway. Do I spend my money on a cartridge filter, keep my water, and hope it's small enough to filter out the flocc-ed gunk, and be a better overall solution?
    Or do I get a smaller cartridge filter and run it in series with the sand filter as a multi-stage setup to catch what the sand can't? That's about a $75 option.
    As you can see, I'm not made of money here, ha.. but I'm feeling like an *** because my kids can't swim yet this year.
    So.. where do you think my money is best spent?
    Re: Need to stop just throwing money around randomly.. [FILTER]
    We recommend avoiding flocculates. They can speed things up a little, but often cause far more trouble than they could possibly be worth.
    From your description, your multi-port valve needs a new spider gasket. That is a fairly easy repair. Still, it would not cause the water to turn cloudy. Cloudy water is invariable a chemistry problem. If you post a complete set of water test results we can give you suggestions on getting your water chemistry in line.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Quote Originally Posted by JasonLion View Post
    What he said
    Support the site
    Dec 2012
    Manassas Park, VA
    207
    The leaking water into waste most certainly sounds like a spider valve issue. I recently replaced mine for under $14.00.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Yea. Lousy flocculant. I didn't want to do it, but I threw it in in a fit of desperation.
    As for the spider gasket, From what I read, my model doesnt have a serviceable spider gasket and you have to replace the whole head. It's the Hayward Pro s166t - And you're right, I don't think it's really the issue, but with it throwing a visibile leak on "recirc" who is to say that when It's on filter it's only actually filtering 20% of the water or so and letting the rest just fly by. I dunno.
    I don't have a fancy test kit yet, but Basic numbers show
    Free chroline: 3
    total chlorine 5
    CYA ~20
    TA ~35
    PH: bouncing a bit from 7.0 to 7.5 - I've been adding washing soda
    As for cloudy water being a chemistry problem, I understand what you are saying - The **** will settle out and the water is looking good (ya know except for the inch of yuck on the bottom) - If I filter it all gets trapped in solution and becomes cloudy. Seems I'm just not able to actually filter the stuff out, either due to a sand filter not being "good enough" or it bypassing the filter.
