Results 1 to 10 of 10
Thread: Low speed with 2 skimmers sucks....
    Jun 2013
    Newcastle, Oklahoma
    508
    actually, it doesnt suck at all. The water in the skimmers seems almost stagnant with no skimming action at all. i guess with 2 skimmers and the lower impeller speed it just cannot generate enough suction. I either have to close one skimmer or hit the high speed switch. Im in the country with a lot of bugs in my pool in the a.m. so good skimming action from both skimmers is a must have.
    is there anyway to fix this or is this just the downfall of 2 speed pumps and if I want to skim I will just have to run high speed?
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Jan 2013
    Houston, TX
    1,079
    Re: Low speed with 2 skimmers sucks....
    I have my timer set to run 15 min of high first thing in the am. Seems to solve the skimming issue.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by karmabiker View Post
    Sent from my iPad using Tapatalk
    my pump just has a high-low switch on it. i have to hit it manually. is there a timer that can override that for auto speed control?
    EDIT: looking around, there are timers, but they all seem to be for pumps wired on 220v. Mine is 110 plugged into a timer, thats plugged into a GFCI outlet.
    Oct 2011
    Minnesota
    164
    Do you also have a main drain? If so, maybe consider turning that off so you get better skimming performance on low speed.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    The Intermatic T105 timer will switch pump speeds on a daily schedule and works with 120 volts.
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by jmhjgh View Post
    no main drain.
    Quote Originally Posted by JasonLion View Post
    thanks Jason. Ill look in to that one...
    38,237
    You will have to rewire the pump though if it just has a power plug now. I assume the speed selection wires are available in there somehow.
    Can you close off the upwind skimmer?
    Jun 2013
    Newcastle, Oklahoma
    508
    yeah, its just a power plug. there is a switch on the underside of the pump for hi - low - off. rewiring will probably be a pain.
    i can and do close the upwind skimmer on days the wind is blowing, as the upwind skimmer wont catch anything anyway, best to double the power to the one catching all the debris.
    to be honest though.... the suction is not really great even if I close the other skimmer. I know running a pump at 1/2 speed is going to affect suction... but I really wish it was better than it was. I work nights and am at home all day. Pool pump comes on 9 am to 1pm and 8 pm to 10pm.
    I add my bleach at 9 am for the day, and usually kick it up on high to do so for better distribution. I think I will just keep doing that and letting pump run on high for the first hour or so, then manually switching it to low. I home all day anyway until 3 pm....
    and often... my kids and I are in the pool anyway....
    Do the skimmers have weirs?
    Support the site
    Jun 2013
    Newcastle, Oklahoma
    508
    yes. they both have weirs. the are both the Doughboy Skimline Deluxe skimmers.
