Results 1 to 7 of 7
Thread: too much salt in pool
    my salt reading is 5700, ideal is 2500
    i didn't add the salt, local pool guy did it for me when i was a beginner
    is there any harm in this? its been like this for a while and water has been balanced well. everything is good except this.
    anything i can do about it or should do?
    thankyou.
    38,290
    Re: too much salt in pool
    If the SWG is not complaining (although I am surprised it is not), then you are fine.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    the salt will gradually lower with splash out and backwashing if applicable
    how are you getting these test results?
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Quote Originally Posted by aussieta View Post
    test results from pool shop (my pool shop is one which is actually phenomenal, very rare).
    May 2013
    Fort Lauderdale, FL
    423
    Look up the manual for your SWG and see if that level is in range. It gradually lowers though filling pool with your hose, or rainwater, so I'd let it go.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    I was just going to post the same question - I just got the salt test kit and the first reading was 4800 - clearly more than I need. But I will just let it go based on your comments.
    Thanks again - the advice on this forum lets me chill out and enjoy a cold one by my pool yet again!!!
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    If the SWG is happy, you should be too. Two things to remember:
    1) We seldom trust pool store testing
    2) If it ain't broke, don't keep fixing it 'til it is!
