Results 1 to 14 of 14
Thread: Just got my TF-100 and have a plan of action. Double-check before I break something?
    Jun 2014
    Orlando Florida
    4
    Cool Just got my TF-100 and have a plan of action. Double-check before I break something?
    Hi all... first time poster
    Little background
    So just recently bought a house w/ a pool and been semi-wingin' the pool maintenance... and it looks like **** - go figure.
    About a week ago in desperation I dumped about 3/4 and refilled fresh from the hose. Looked pretty good! Tested w/ the cheap little strips... Everything was great! ...for about a 2 days.. and the boom worse then before.
    After that I figured it was time to buckle down and learn how to do it the right way and wound up running across this site! Immediately ordered a TF-100 xl, auto-mixer dealio, borate tests... whole deal.
    Today
    So, it came in today and after the kids knocked out it was like christmas. Felt like a mad scientist w/ all this stuff lol.
    So I got some starting numbers and have devised a plan of attack but was hoping someone might double-check my noob-logic before I finally do the pool in for good.
    So here's the dirt - be kind
    FC: 0 (I know I know...)
    CYA: 25
    PH: 8.2 (Or higher??? was same color has highest one)
    TA: 100 (wow, this actually seems ok)
    Devised Plan of Attack
    1) Lower PH to 7.5
    2) Slam Slam Slam
    3) Raise CYA to 45
    4) Re-survey and devise next plan of action
    Breakdown of Plan
    Lower PH to 7.5
    -Start w/ 20oz of 31.45% Baume (or equivalent) acid and re-check
    Slam
    -Raise current FC to 11 via 1.7 121oz jugs of 8.25% bleach (I have a bunch of this)
    -Follow other steps of slam process
    Raise CYA to 45
    -via 32oz (weight) or 34oz (volume) stabilizer
    or 84oz liquid stabilizer
    So, look ok? Or am I about turn my pool into some toxic soup?
    Thanks for any insight!
    12,100 gal, plaster, chlorine, Pentair C&C Pump w/ Cartridge Filter
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Just got my TF-100 and have a plan of action. Double-check before I break somethi
    You may have won the award for most on the ball newbie. Looks 100% correct. Make sure you keep up on the slam as often as possible; especially for the first day or two. And like you said, don't raise you CYA until after the SLAM is complete. Kudos!
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Welcome to TFP!
    It sounds like you've done your homework before posting - keep it up!
    Step 0 for your plan of attack is to get you FC above the minimum for your CYA. Everything else looks good.
    Post pictures! This site loves pictures!
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    wow, you don't need any help at all, signature filled out and everything
    how do we vote you as a moderator?
    i assume you've been reading pool school and found poolmath
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    WOW Just wow!!! You have done a great job of reading pool school. I have never seen a first timer hit it like you did!! That being said be sure you sweep and vacuum to clear out the dead stuff. backwash your filter when it gets 25% above your clean filter values. other than that you have got it.... Slam away........................ Oh BTW you should post pics. you will be so proud to look at the before and after pics!!!
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum TLB
    What a great job you have done thus far
    Did you also test CH?
    We are going to need pics
    You're done SLAMing when:
    Sep 2011
    Lumber City, Ga
    9
    Well done
    24x48 Atlantic AGP
    18" Hayward Sand Filter
    1 HP Hayward Powerflo LX
    Jun 2012
    Rochester, NY
    247
    Wow. Best first post I've ever seen.
    Would love to see pics and follow this one to completion, unfortunately, I think OP will clear his pool in no time and be too busy enjoying his pool to post here.
    Rick
    Installed June 2012 Aqua Leader 24ft Round AG Influence w/54 inch walls 13,500 gallons
    Cartridge Filter 100SF, 1.5HP
    Aqua Plus Smarte System - In for vacations, BBB all the way.
    Love my PVC Solar Cover Hangers
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    You plan is right on. Brush, brush, brush.
    25k IG vinyl SWG Haywood 4830de 1.5hp TF-100
    Jun 2014
    Orlando Florida
    4
    Wow thanks for such a warm welcome and all the awesome replies and suggestions!
    Yeah I definitely read the pool school stuff - over and over till it finally started to sink in a little I was hoping it wasn’t just my lack of sleep causing a false sense of confidence
    I plan on starting the process in here in just a few (gotta run and grab some acid first) so will post back results as I can.
    Abigail K: Thanks! Will get the FC level up right above min for the current CYA before starting the process.
    Butterfly: Just did it right now: CH = 225. So looks to within range for my plaster pool per the docs I believe?
    MBG75: Will do! Brush at the ready.
    Here are some pics as requested in the mean time - I think the pics make the pool look quite a bit better than it really is actually
    Alright, thanks again all. Wish me luck
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Classic Florida pool! Hello fellow Floridian!
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    Jun 2014
    Orlando Florida
    4
    Hey all back w/ some updates on the SLAM. So far going awesome!
    Been checking and adjusting FC every few hours and have managed to keep it in SLAM mode since my last post on Friday. Definitely a chore when the sun comes out! I've learned the sun = the great chlorine devourer!
    The perseverance has definitely been rewarded though! I've definitely still got a ways to go to get everything else correct...but the difference in just 3 days from the SLAM alone is almost staggering.
    I'll be checking everything tonight and seeing if we're good to bring this thing to an end tomorrow.
    Then it will be time to get a everything else lined up.
    Pictures of a transformation over the last 3 days...
    Friday 6/27
    So as suggested I grabbed the brush and went to town...
    You mean this stuff actually comes up? I just thought the bottom of the pool was always this color. lol
    Brush brush brush
    Getting a little cloudy in here...
    The brush end of the brush... is... gone...
    They say it's got to get worse before it gets better right?
    Good night green soup
    Saturday 6/28
    I awoke that next morning to such a wonderful sight - almost ALL the algae had been eaten by the chlorine. There was a little after that morning's brushing but wow what a difference just one night made!
    Is this really the same pool from last night?
    By mid-afternoon almost all the green hue was gone... just kept getting better and better
    Almost looks good enough to jump in... if you don't mind skin-melting levels of FC..
    Sunday 6/29 (This morning)
    So... By this morning it's just gorgeous.. Still a little cloudy...but BLUE as can be!
    Who's pool is this? Can't be my pool
    So purty..
    So as said going to see if i can hopefully stop the constant baby sitting tomorrow and move on to the next steps in the plan of attack.
    Thanks to all for all the help so far
    Jun 2014
    Orlando Florida
    4
    Quote Originally Posted by Waldog View Post
    Well howdy from over here in Hunter's Creek / Orlando.
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    Nice job!
