Thread: Major jump in TA and PH after adding Borox
    Jun 2014
    Gaithersburg, Maryland
    1
    Hi, this is my first post so forgive me if it's in the wrong section. I have an SWG and my readings this morning were as follows..
    FC 4
    CC 0
    TA 70
    PH 7.5
    CH 150
    CYA 60
    Salt 3200
    ...I figured my readings were just where they should be so, I followed the directions to a T in the post regarding adding Borox to your pool. I used PoolMath to calculate the recommended amount of Muriatic acid and Mule Team Borax I should add. I started up the pump and did the deed. This was at 11:00 am, when I got home from work 8 hours later and took a reading my PH was 8.2 and my TA was 100! Did I do something wrong? I don't recall reading about other people's readings jumping up that high... Do I now go the route of dropping the PH real low again and airating like I did last week to lower my TA?... I recall reading that it was difficult to lower TA once there is Borax in the water.. Any help would be greatly appreciated.. Thanks!
    18x48 Intex Ultra frame pool, 6600 gallons, Hayward XStream Cartridge filter system, Hayward Power-Flo Matrix 1Hp pump, Intex SWG.
    Re: Major jump in TA and PH after adding Borox
    Welcome to TFP!
    Somehow, it isn't obvious how, you either added more borax or less acid than you should have.
    Don't worry about the TA, just get the PH back into range.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Just borated mine and had to add another 64 ounces of acid over what I figured as well. (was probably high already before with all the rain lately) Haven't checked TA. Just worry about the PH.
