Results 1 to 10 of 10
Thread: Stainless poles in pool
    Jun 2014
    White House, Tennessee
    17
    Hello. New to the forum.
    Have been lurking for awhile utilizing a lot of info here. But I have a question I can't seem to find an answer for.
    I have staining in my pool and am curious if some new stainless poles on my ladder could be the cause.
    I'm not ruling out algae but with the introduction of the new stainless poles on my ladder could that be a possibility?
    Could these poles increase metal content in my pool or does the metal have to be microscopic?
    Thanks
    Casey's Avatar
    SW PA
    10,427
    Re: Stainless poles in pool
    More than likely, the ladder is not the cause of the staining in your pool. You have metals (copper or iron) in your water that has caused the staining. Are you on well water? Have you been using algaecides? Do you have a heater?
    30,414
    For you to have a metal stain in your pool, the metal must be in soluble form and then precipitate onto your pool surfaces.
    A pic would probably be very helpful. How long have the poles been in your pool? How old are the stains?
    Jun 2014
    17
    Thanks for the response. Poles been in about 2 months.
    I did not plan on getting into the depth of my issue without first properly testing my water. I have ordered a FAS/DPD chlorine test kit and should be able to report back the results.
    And I will update my signature with pertinent info on my pool.
    One thing to note is, yesterday I raised my chlorine level and the stain went 80% away.
    But rather than you having to guess at my issue because of lack of information I will wait for my tester and report back.
    Thanks for the info already provided.
    Jun 2014
    17
    I had an issue with my order so it was cancelled on the test kit.
    Maybe a good thing so I can make sure I am getting the right thing.
    Is the below test a good one to buy? Or should I go with something else?
    I am planning on re-ordering soon.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I'm pretty sure that is one of the recommended test kits. The other being the TFTest kit. The TFTest kit might cost a little more, I can't remember but it is the better bargain for the amount of reagents you get.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Casey's Avatar
    SW PA
    10,427
    You will get a better deal with the TF100 but that is up to you.
    Jun 2014
    17
    Quote Originally Posted by Casey View Post
    Thanks. Thats why I am here. Lookin and a learnin..
    Jun 2014
    17
    Do you happen to have a link to the TF100?
    Jul 2010
    Philly
    332
    Quote Originally Posted by wado66 View Post
    Here ya go. TF-Test Kit
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
