Thread: Who has some ideas for removing a stripped screw in light underwater 1/2" recessed?
    May 2014
    Millersville, MD
    46
    My pool light looks a lot like this:
    Unfortunately the top screw is badly stripped and I can't get it out. I am trying to remove it to find any signs of algae that is sucking up my chlorine. I don't want to drain the pool as I literally just did that to lower my CYA, refilled and have used almost $100 worth of chlorine SLAMing. The screw is recessed into the plastic about 1/2" so I can't get vice grips inside to try and grab the screw head.
    Any ideas on what I can do?
    ~21,000 gal, IG Vinyl w/Liner, Hayward Pro-Grid DE2420 DE filter, Built: ~2002, manual vacuum, K-2006 Test Kit
    38,274
    Re: Who has some ideas for removing a stripped screw in light underwater 1/2" recesse
    Someone recently used a pneumatic driver under the water to do something similar .....
    Apr 2013
    Sacramento, CA
    2,769
    Get a "screw extractor" at home depot or Lowes. They often work. Never used one on a pool light screw.
    Butterfly's Avatar
    South Carolina
    10,045
    Google it. You will get lots of ideas. One is to try stretching a rubber band over he screwdriver tip. Another is simply use a different type screwdriver. An easy-out/screw extractor was DH's first thought.
    You're done SLAMing when:
