Thread: First pool tests with my new TF-100
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I posted this in my introduction thread, but I realize it probably should've been here instead.
    Here is my first set of numbers:
    PH 7.6-7.7
    FC 8
    CC 0
    CH 425
    TA 70
    CYA 50
    Those were at noon yesterday. Last night at around 10pm I checked the PH and FC again and got 7.8 and 7.5 respectively. I had turned the SWG down a bit when I got the FC of 8 yesterday.
    The SWG has 5 plates in it, so I believe that makes it a Resilience A5 which is rated for a pool up to 40K gallons. The pump does not have a timer on it, so it runs 24/7. I will put a stop to that as soon as I have a chance to wire in a timer. One thing I am wondering about is the mineral pack that they were using. I took it out when we took possession of the house. It has a center core that dispenses tri-chlor. The outer pack says it has silver chloride and something else. I can't remember what it was. I didn't see anything about copper on it, so hopefully that means I don't have copper in the pool. I'm gonna see if a local pool store can check the salt and metal content for me. I'm also planning on adding a little CYA, and some acid to keep the PH in check. How does everything else look?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Aug 2010
    Dallas, TX
    4,052
    Re: First pool tests with my new TF-100
    I'm guessing it is dichlor, unless your tap water is hard where you live. The reason I say that is your CH is high, and CYA is not.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    It may have been dichlor. I'll double check tonight. That part was empty either way. Our water is pretty hard here. I need to test my fill water. I haven't gotten around to that yet.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    The frog system had trichlor. It also says silver chloride and carbonate. Is that silver or copper carbonate I wonder? I think I also found why the CH is so high.
    Here are the numbers I ran on my fill water.
    FC 1
    PH 7.6
    TA 150
    CH 175
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    According to pool math it looks like I need to add some CYA. I'll add the recommended amount to make a step to 60, then later add more to get to 70. Add some acid to drop ph to 7.5. The CH is a little high, but the CSI is in the safe range, so I assume it will just get diluted with rainwater eventually. Does all that sound about right?
