Thread: Intermatic pump switch not turning pool on
    I have a fiberglass 10,000 gallon in ground pool with an Intermatic timer. Today I was in the pool all day and the pump was on from it's regular time...10-5. Around 5pm I decide to vacuum the pool (which I need the pump to be on for) and as soon as I came in, the pump timer went off, shutting the pool pump off (I didn't even realize that it was 5 already, or I wouldn't have even bothered to vacuum). Anyways, I went over to the pump to manually switch it back on, and it would not turn on. I have been messing with the on/off trippers, trying to get in on now for about 45 minuets, but it will not go on...anybody know what the problem could be?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Intermatic pump switch not turning pool on
    Change the time. Right after it shuts off, you can't turn it on because the trippers are in the way. So set the clock forward an hour or two and it should flip on just fine. Then set it back when you're done.
