Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Blacklisted Pool Install
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    I have been a part of this forum for just under a year and have learned so much and have so much to learn still. My wife and I purchased a 15' Intex steel frame pool at the end of last summer. It was so hot at the time I figured it would be good to go just setting it up on the grass and hoping it would be level enough to get us through the rest of the heat wave and then I could do it right.
    So this year has been busy as all can be and I'm behind the power curve with setting up the pool. I rented a sod cutter a couple weekends ago to get the progress started. A buddy and I cut the sod and used the sod cutter to "rough" level the ground the best we could before final leveling. I had to cut out close to a foot on the back side by the fence and the sod cutter worked great where the ground had some moisture in it. Where it was dry and rock like it didn't work as well but we managed to get most of the rough cut dirt out the first weekend. For the last week and a half I have been working on leveling the pavers for the legs a little at a time. Instead of attempting to level the site first I am putting in the pavers to the lowest point and working from there. I am using a water level to get the pavers to within 1/4-3/8" of each other and the "Golden/lowest" paver. What a pain! Once I get all the pavers leveled then I will chip out in between the pavers to get it leveled the best I can and then fill with sand to the paver level and tamp/pack the sand.
    Questions I have, 1. With me using sand would it be advisable to put down the foam insulation on top of the sand or will I be fine with just the sand? I'm worried about the sand possibly moving around/washing out from under the pool. I live in southern California and we don't get much rain so I don't think I will have to worry about that too much. My thinking is that the foam will spread the load of foot steps etc. that could possibly happen in the sand. Is that possible or am I over thinking this?
    Right now I have a 1200gph Intex Sand filter/pump that I got with a SWG/Filter/Pump combo last season for a great price. I am also working on how to get the SWG working with the Sand filter/pump and by passing the pump and filter on the SWG. I want to add the in wall strainer and hard plumb everything but that will be down the road a while. Right now I just want to get this thing up and running again.
    This is what I have so far for pics, I didn't get a before picture but I have an old pic I will put in for reference.
    The pool is going in strait behind the patio cover toward the fence.
    A couple after the sod was removed and rough leveled with the sod cutter.
    You can see where I need to get the level to in the middle back.
    Setting out the brick and frame for placement
    Sinking and leveling the pavers in the rock hard clay we call ground.
    Getting there.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Blacklisted Pool Install
    Hi there, and welcome... Levelling sux, but you're doing a great job..... I'm tuning in for this build...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Looking good! I had to chuckle tho. You need a pic axe to dig in your hard clay. Here in NE Florida, if the sand is dry (which doesn't happen often) the biggest problem I had was loose sand filling the hole as fast as I scooped some out. If it's damp, it works some better.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Casey's Avatar
    SW PA
    10,457
    I hate clay! When it's dry, it's like digging through a sidewalk and when it's wet, it sticks to everything!
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Yeah, I lived in Munford, TN when I was a kid. Thick, sticky, gooey red clay. My dad got his Cadillac stuck a block from home one day. He came walking home, arms full of groceries from the commissary in his dress whites. Can you say "stained"?
    Angie M.
    Sep 2013
    El Cajon CA
    126
    Thanks everyone for the encouragement.
    I got the rest of the pavers leveled last night. I am going to get a truck load of sand and start leveling the ground in between the pavers. My thought with the ground in between the pavers is that it won't have to be perfect level and the sand will fill in the low spots after I chip out the rock hard ground. I hope to get most of the leveling completed this weekend and possibly get the sand in and leveled and tamped. Will update when I have more progress.
    Sep 2013
    El Cajon CA
    126
    DG as fil/basel?
    Please keep all pertinent information about your build in your build thread where everyone can view it and answer any questions you may have. Thanks Casey~
    I'm in the middle of leveling and setting up our 15' steel frame pool. I was thinking of using sand to level the ground but found out that I can get 3/8" screened DG for about the same price and think this will be a better option. Has any one used DG as a base/leveler?
    My thread is HERE with pics.
    Thanks everyone.
    Sep 2013
    El Cajon CA
    126
    Sorry Casey I will keep all questions in the tread.
    So I'm hoping that the DG will make a better base than the sand would have. The guys at the rock yard said that a lot of people around this area use it for a base and that it should compact better than sand. Hope they are right.
    Casey's Avatar
    SW PA
    10,457
    It's good stuff. I'd of used it as my base but, I had a lot of things going on that I didn't use it. I wish I would have.
    Sep 2013
    El Cajon CA
    126
    OK, got some more work done this weekend. I got most of the easier dirt out and leveled. There are a couple spots that are as hard as rock that I need to use the pick ax to break it up. I picked up a truckload of DG Friday hoping I would be able to put it down before the end of the weekend but didn't get to that point yet. I plan on renting a plate compactor to pack the DG when I get it down and leveled. A couple pics of the progress and how I did it. I used a 2x4 across the pavers that are all leveled to within 3/8" using a water level. I dug out so there are no high spots and tried to keep the depth under 1 1/2 or so. I just eyeballed it and didn't measure the depth. I figure if I have to get another load of DG it only cost me $28 for just over a yard of it.
    Question- Since I'm using the DG as a base should I also put the foam down or will the DG be good enough? If I use the foam under the pool I have to put it under the legs as well correct?
    Ok on to the pics.
    My audience watching me work. They also think they are helping Dad by digging, but in the wrong spots! So it's been a love hate relationship lately.
    My depth gauge across the pavers
    Making progress
    Looking better
    Sep 2013
    El Cajon CA
    126
    So I got all the high spots out and am ready to put the DG down tonight. I hope I have enough DG to fill it up. I will rent a plate compactor and compact it. I can finally see the light at the end of the tunnel!
    Sep 2013
    El Cajon CA
    126
    A buddy came over last night and we got the DG down and ready for the plate compactor tonight. When we walked on it, it seems to pack nicely. We did a test area where we used the hand tamper with some water and it did a good job but I will rent the compactor and do it right the first time. After we got it down and leveled I soaked it good with water to help compaction. This is a lot more work than I initially thought. Hope to have the pool up and started filling tonight.
    The latest pics
    Sep 2013
    El Cajon CA
    126
    So got it up, filled and enjoyed this past weekend. Decided not to use foam under the pool, just a heavy duty tarp. I hope I don't regret that decision but the DG compacted nice and smooth. I'm getting everything dialed in before I put the SWG on it. I have to patch a small hole and tidy up the back yard from all the stuff I had all over the place. So on to the pics.
    After compaction
    Pool set up and started filling
    Finished and usable
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Beautiful! I see all kinds of floaties but no one in the pool! Put down the camera and jump on in! You worked hard, it looks great now on to the fun!
    Angie M.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Looking at your waterline - that's an awesome job of levelling. Congrats!!
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Sep 2013
    El Cajon CA
    126
    Quote Originally Posted by Taterfink View Post
    Trust me we were in almost all weekend!
    Quote Originally Posted by GreatCanadian View Post
    Thank you. Yes it was tedious and took forever it seemed like but well worth the effort to get it right this year.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    You did awesome!
    Angie M.
    MrsDimples's Avatar
    Jun 2014
    England
    47
    Lovely!
    I hope you have lots of fun
    Intex 10ft Metal Frame - 1,185 gallons
    Intex 530 gall. per hour Filter Pump (Model No. 58604) - Cartridge
    Chlorine / pH dip sticks
    Intex 3kw Heater
    Nov 2013
    Ramona, CA
    46
    [/QUOTE]
    That looks like to me a little Yamaha Tri-Zinger 3-wheeler next to the fence!
    2013, IG, Gunite/StoneScapes, 16'W x 36'L x 3'-6'D, 15K Gallons, w/ 8' Spa - Pentair Intelliflo variable speed pump - Pentair MasterTemp heater 400K
    Pentair Intellibrite LED lights pool x 2, spa x 1 - Pentair EasyTouch 8 controller w/ hand held wireless - Pentair IntelliPH
  20. Back To Top    #20
    May 2014
    Oro Valley, AZ
    120
    You know it took me 5 minutes of reading this thread to figure out why your pool install was "blacklisted"....lol.
    Gil
    In-ground: 20,600 gallons; Sand Filter 1HP pump; Kreepy Krauler; Solar Breeze Solar Powered Robotic Skimmer; TFT-100 test kit
