Results 1 to 8 of 8
Thread: Should I ignore the pool store tests?
    Jul 2013
    Midwest City, OK
    6
    Yesterday I recorded the results of the tests included with my TF-100 test kit and compared it to the test results from a local Leslie's and a Bio-guard products store. The results differed between each testing site. FYI, first pool for me and this is about the 10th time I've performed all the TF-100 tests.
    Should I ignore everything but the TF-100's test results? Any suggestions (raise TA and CYA)?
    thanks
    Mike
    -------------------Leslie's / TF-100 / Bio-guard Store
    Free Chlorine------3 -----/ --3 --/ -1.8-
    Total Chlorine ---- 3 ----/-3.5 --/ -1.8-
    Salt --------------- 2500 / 2970 / -3000-
    CH ---------------- 210 -/ -270 -/ -360-
    CYA --------------- 99 --/ --40 --/ -35-
    TA ---------------- 90 --/ --70 --/ -68-
    pH ---------------- 7.5 -/ --7.3--/ -7.2-
    The water is Crystal Clear. Instant salt reading from SWG = 3000, water temp 84.
    Built 2007, 22K, IG, Plaster, Filter- Pentair FNS Plus 36 (cellulose fiber), SWG Hayward (T-cell15), filter pump-1.5hp (single speed), Pentair Legend pool cleaner(1.5hp?), TF100 test kit, Aquachek strips.
    Oct 2011
    Minnesota
    164
    Re: Should I ignore the pool store tests?
    Were you still having it tested at the Pool store just to see if it matched your own tests? Myself, I trust my own readings, and if you have a clear pool, than it must be working.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    30,402
    A tenant of TFPC is to trust your own testing. The TF-100 exists to keep people out of the pool store, instead relying on their own ability to test and interpret the results. Trust your own testing. Trust your own testing. Trust your own testing.
    Butterfly's Avatar
    South Carolina
    10,045
    Always trust your own testing!
    Now, I suggest that you retest the CYA and confirm 40. Then add CYA via sock method to reach 70. Dial in the SWG to maintain FC.
    Leave TA alone, it is fine. Besides, it will lower on its own over time when you lower the pH with muriatic acid.
    Have you seen the SWG balance article in Pool School ?
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    Water Balance for SWG's: http://www.troublefreepool.com/conte...rine-generator
    Oh, did we mention, trust your own testing
    Welcome to TFP
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Quote Originally Posted by Butterfly View Post
    Welcome to the forum Mike
    Sock method is to put it in a sock and then put the sock in your skimmer. Best to go in there a couple times a day and knead the sock. If you work it some it will dissolve quicker. If you just let it lay in there it can take a few days.
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2013
    Midwest City, OK
    6
    Yep, just doing a comparison with my tests.
    Jul 2013
    Midwest City, OK
    6
    I like trusting my TF-100, I love it and I will trust it!
    Welcome to TFP
    I had seen the "Water Balance for SWG's". I enjoy pool school and have spent a lot of time reading here. Love it. I will trust my measurements.
    Thanks!
    I hadn't seen how to add CYA, the bottle of CYA I bought simply tells you to poor it in and brush.. The sock method sounds like the way to go.
    thanks!
    Quote Originally Posted by kiss4afrog View Post
    Will do
    Thanks!
