Thread: Pump running time.
    Jun 2014
    pensacola,fl
    104
    Pump running time.
    I first off want to say hi to everyone and thanks for this website. There is so much useful information in this site. I am a first time inground pool owner. I have had multiple above ground pools though. My question is I have a Pentair Intelliflow variable speed pump. Right now it set up to run at 2450 rpm for 10 hours a day. I'm wondering if I could get away with a lower RPM for a longer period. If I could run it about 1500 RPM for 24 hours a day I would save approximately 5000 watts a day. What are your thoughts on how long to run this pool and what RPM? Thank you in advance for any information you might be able to help with.
    18x36 ft in ground vinyl liner pool Approximately 27000 gal. Pump is Pentair IntelliFlo variable speed pump with Hayward sand filter and Hayward Aquarite Salt System with T-15 Cell. K-2006 Test Kit
    38,295
    Re: Pump running time.
    Welcome to TFP!!!
    Check out this article from Pool School and post back if you still have questions: Determine Pump Run Time
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Many variables are involved in how long you need your pump to run, but realistically you only need the minimum amount of time to filter the water and keep it clear and circulate any chemicals. You don't show a SWCG in your signature, so you don't have that variable to add to the mix. You will probably need to experiment with speeds and run time before you can dial in what your specific pool needs.
    Welcome to TFP!!!
    oops, I forgot about that article.......
    Support the site
    Jun 2014
    pensacola,fl
    104
    Thank you I was looking through pool school before posting but I couldn't find that. Thanks again!!
