Thread: Electric from sub panel to heat pump - conduit question
    Jun 2013
    Philadelphia, PA
    143
    I'm running electric from my existing subpanel to my heat pump (Maybe 10' of line?) 220VAC 40amp line. I'll be running at least #10 copper.
    Question is, what do I need to be using for conduit? The pool installer used a mix of flexible whips and solid pvc. So not sure what's used and when, or if it matters? Everything coming out of my subpanel now is solid, with the exception of the short line over to the SWG box. The connection for our pool lights changes from solid to flexible. And, guess I never noticed, but the power for our pump actually comes from the SWG box and that's flexible the entire way.
    Picture, if it helps. Far right box is the subpanel.
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Electric from sub panel to heat pump - conduit question
    I would personally use Liquid Tite Conduit. This was the first one I found, but different brands are available at the big box stores.
    Support the site
    Jun 2013
    Philadelphia, PA
    143
    Yup, that's exactly what I was planning, as long as flexible conduit was ok. Looks like code says it must be secured within 1 foot of the connector, and 3 feet along the way. Looks like that's going to be the plan unless I hear otherwise.
    TFT 100
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by TroubleFreePat View Post
    Support the site
