Thread: Bumping up FC before two day trip
    Scice77's Avatar
    May 2014
    Central Jersey
    17
    Quick question, my current FC target is 5 ppm. If I go away for two days, what number can I safely bring my FC up to to keep things in check until I get back? I am currently losing 1 ppm FC overnight and adding 50 oz of bleach nightly to maintain. Here are my numbers. thanks in advance for the help and for all the help in the past
    FC-5
    CC-0
    PH-7.6
    CYA-40
    TA-80
    33K gal. Super Steel Grecian IG (built 1994), Vinyl Liner (Replaced 2013), Jacuzzi EW 75 DE Filter (Original 1994), 1 HP Heyward Super II Pump, TF-100 Test Kit, Polaris 380 Cleaner
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Bumping up FC before two day trip
    If you're cyan level is 40, then it's safe to swim up to level of 16. With 1 ppm loss per night and 0 CC, and you're only leaving for 2 days, I don't see any reason to target beyond 8 or 9.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
