Results 1 to 13 of 13
Thread: "Hibernating" a pool for 10 years
    new_to_pools's Avatar
    Jun 2014
    La Quinta, California
    2
    Hi everyone, I'm new to pools!
    I have an income property with a long term lease (5 to 10 years), and the lessee doesn't want to deal with a pool.
    The pool was built in 1995, made of plaster, in the Palm Springs California area.
    It has been proposed to: drain the water / fill with sand / cover the pool for 5 to 10 years.
    When the lessee vacates: remove the sand / repair (re-plaster, caulk, fix tiles, possibly replace filter and motor).
    My questions:
    1. Has anyone had experience in hibernating (or retiring a pool) for an extended period?
    2. What would be some of your recommendations?
    3. Are there alternatives to filling with sand?
    Thank you
    IG, plaster, Freeform, with Spa, built 1995
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: "Hibernating" a pool for 10 years
    Can't help you, but what a shame. That's a beautiful pool.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    If you leave the pool drained you will need to drill holes in the bottom of the deep end (or open the hydrostatic valve in the main drain if you have one). Otherwise the pool could float out of the ground.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by GreatCanadian View Post
    Yes it is.
    You're done SLAMing when:
    Jan 2013
    Houston, TX
    1,079
    I would put an swg on it and hire someone to come out weekly to brush / vac and add ma - test with a tf100 and report back. Bound to be cheaper than filling with sand then reclaiming later and the lessee would get a pool without the hassles.
    If you do fill it I would have something written into the lease about a very large penalty if the lease is broken to compensate for the pool recovery.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jan 2013
    The Great State of Texas
    243
    Can you not find a different person to lease it? No way would I be comfy with that situation. I agree that at the very least I would have someone come in and clean it weekly. I just can't believe that there isn't someone out there that would be dying to lease a house with a pool!
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    25 year old pool w a facelift in 2014
    Casey's Avatar
    SW PA
    10,450
    I would hire a pool company to care for it if at all possible. That is better than filling it in!!!
    It seems odd that someone would rent a place with a pool when they really don't want a pool.
    Maybe lease to someone else or sell it to this person and let them do what they want.
    Support the site
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    We just 'opened' our pool after 8 years of no use. So far things are ok and I'm waiting to see if it stays that way!
    IG dark Gunite pool located in NY. I left the pool filled with water, poured a ton of bleach in it, installed a loop lock cover. That's it.
    every so often in the warm months I threw some more bleach in as I was concerned about Mosquitos. Was going to throw some gold fish in for skeeter control but I stayed with the bleach
    When we drained it we were fully prepared to marble dust it. I also though I would see major cracks or chunks of the sides out. At least some of the waterline tiles off. Nutten!
    I expected to find the remains of some critters but the loop lock did a great job and we just had a lot of seaweed type growth
    After the major cleaning we were told by the pool repair company that the only need for dusting would be cosmetic, so we passed for this year as we had a major project going on with over 2500 ft of pavers, regrading, drainage, retaining walls, fencing etc.
    Although the plumbing was ok we re plumbed everything above ground.
    Cracked the egg filter, sand was caked up but everything else was ok so we had it cleaned & fresh sand was installed. Had the Laars oil heater rebuilt as it became a hotel for mice and they use the combustion chamber for nesting material. Had all the AC wiring checked and repaired where needed. Found the superpump that I stored in the garage for the 8 years hooked it up to the new plumbing and it's working ok. May replace with a 2 speed or VS.
    Most of what was needed to be done would have been covered by good routine maintenance over the years so the cost of 'closing it' for the 8 years was minimal.
    I also think we were lucky and we may still have issue with the surface but time will tell
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Jul 2013
    Akron, OH
    27
    That's a beautiful pool and back lawn.
    It would probably be cheaper to keep the pool open for that period of time than it would be to carefully fill it in and then years later carefully dig it back out, make an unknown amount of repairs, etc.
    I would be inclined to insist that it be kept open and include the pool maintenance in the lease amount. At the very least you will have to factor into the lease all the costs of filling it in and then opening it back up years down the road.
    Vintage 1980 Buster Crabbe Lazy L, 21,500 gallon, In-ground, Vinyl, DE Filter
    May 2013
    Fort Lauderdale, FL
    423
    I'd get a loop loc cover (solid with mesh drains) for it (love mine) and put a sump pump on the step to keep the water level below the tile and let it swamp. You can always drain/refill it when the time comes to open it.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by zimm View Post
    id either do that as a 10 year swamp or a 2 year swamp is really no different or if there was wiggle room in the lease amount to cover for weekly pool maintenance, see about hiring it out. I know if I didnt necessarily want a pool, I would at least accept it if I didnt have to lift a finger to maintain it.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Jun 2014
    2
    Thank you ALL for your replies, you all have been very helpful. Loop Lock Cover, sounds like a good idea.
    There is no fence around it, so I would have to make sure whatever covers the pool is solid (or that it supports sufficient weight so nobody can fall into the pool).
    Letting it "swamp out" might be a solution!
