Thread: Too much salt and cloudy pool
    Jun 2014
    Selbyville
    1
    Unhappy Too much salt and cloudy pool
    Hi,
    I am really hoping to get some help with my pool.
    I own an above ground pool that is 24 round 4' deep. I converted from chlorine to salt using a SWG and added the proper amount of salt that it called for.
    My pool has been cloudy and I can not figure out how to clear it up. I had all my readings at the levels that they should be but my salt keeps reading high and the pool stays cloudy.
    I am using the HTH 6-way test strips and salt strips and my readings as of now are....
    Salt: 7.0 3950 (this number has never changed)
    TH: 200
    FC: 0 (It was reading off the chart but now it is reading none)
    PH: 7.2
    ALK: 80-120
    Acid: 50-100
    At this time, I have the SWG turned off because I don't want to cause any damage to it.
    I have shocked more times than I can count.
    This has been going on for a month now.
    Please, any help that I can get will be greatly appreciated.
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    Re: Too much salt and cloudy pool
    What is the Combined Chlorine number?
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
    Sep 2013
    DFW Metroplex
    119
    I would recommend you to get a TFP approved test kit, either TF100 or Taylor K2006, in order to do a proper slamming you need any one of those kits, results from test strips are not reliable and it cannot do FAS-DPD Drop-Test.
    Shock and Maintain
    Make sure you meet the Prerequisites before start the slamming
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
