Thread: How to lower PH?
    Jun 2014
    Russell Springs, KY
    1
    Question How to lower PH?
    I have been reading this all day...think I'm ready to start, but to start...the first step is to get ph level to the 7.2 area...Mine is at 8.2. Have not seen anywhere how to lower this to get started. Help please...waited all day to start...just to run into this brick wall.
    Thank you
    38,251
    Re: How to lower PH?
    Welcome to TFP!
    You need muriatic acid.
    Check out the recommended chemicals article in Pool School.
    Jul 2014
    Berks County, PA
    206
    Why do you want to go all the way down to 7.2? That is approaching the acid side of the scale. It's still in acceptable range, but a bit low. There is also the dry acid option if you don't want to work with muriatic acid. I know that (MA) is what is recommended here, but I still like dry acid (sodium bisulphate). Definitely read on the pool school side of the forum as it will provide you with alot of information. Also learn about plugging your results into an SI calculator to get an overall understanding of how water balancing works.
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
    Jul 2014
    Bastrop, Louisiana
    199
    At a pH of 8.2 the effective chlorine level is ~15% of total volume
    At a pH of 7.2 the effective chlorine level is ~61% of total volume
    To do the same amount of work, you would need 4 gallons of bleach at a pH of 8.2 vs one gallon at a pH of 7.2
    Information was taken from here
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by one_knight4u View Post
    That relationship does not hold true when there is CYA in the water.
    See http://www.troublefreepool.com/threa...ull=1#post4120
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
