Thread: Pumping remaining water out with pool pump
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I have about a foot or so of (gross) water I need to get out for liner replacement. Is is possible to use the pool pump to do this given that it would either be sitting on the deck or I'd have to find a longer hose and go over wall? Any placement/priming issues?
    Thanks!
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Pumping remaining water out with pool pump
    My intex pump wouldn't lift water out of the pool. Your best bet would be to rent or borrow a sump pump.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Jun 2013
    Manitoba, Canada
    153
    I agree, the pool pump will not "lift" water, you need a sump or utility pump to get the rest out.
