Thread: Even Mods make mistakes ...
    38,524
    Talking Even Mods make mistakes ...
    Found that my FC had dropped down to 2ppm the other day, lower than it should be. Water looks fine, but hard to tell due to all the tree junk falling in it.
    Last night put 4 jugs of 10% bleach in to raise the FC up near SLAM level to try to head off a problem and left the pump on high speed overnight with the SWG on to try to capture all the floating junk.
    This morning wife messages me ... the pool look very clean. Since all the tree stuff was in the skimmer
    Sitting at work today and read a thread about how the SWG should generate on low speed no problem. 2 hours later I have a realization ... didn't I notice that the flow meter seemed awfully low the other day and that I likely need to backwash the new fiber I am trying? ... If the flow is that low, maybe the SWG is not generating on low speed which is most of the time now since solar is not being called for
    Well, wife just check the read out on the ProLogic ... SWG No Flow
    Time to get off my rear and get the filter cleaned out
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Even Mods make mistakes ...
    True enough tho, it could happen to anyone!
    You're done SLAMing when:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    It happens to the best of us bliz! Other aspects of life take center stage every now and then. I'm sure you will get the pool back to top form in no time.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    I'm kinda wondering exactly how much "flow" or pump rpm's is required to actually make a SWG-------GEN.
    38,524
    Well around 10gpm is not enough
