Thread: Need help identifying plumbing...please?
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Hi all, I need help identifying my plumbing lines. I've had a pool for 3 years (was already installed when I bought my house) and I though I have a good handle on BBB chemistry, I need some help understanding where all the pipes go and what they're doing. I'm fairly handy--changed my SWG cell by myself, changed the sensor, and most recently attempted a deep wash of my sand filter. That's how I found out I don't know as much as I thought. I tried to close off the water inlets and outlets to keep the water inside the filter so that it would run over the top, but it never did. It went out the waste pipe, and I could never get that closed off. Here is my setup and what I think things are...can you take a look and see what you think? I'm afraid to turn pipes on or off for fear of seizing something up.
    2 main drains in bottom of pool, 2 skimmer baskets, 4 returns, 1 dedicated vacuum return, 1 bubbler, 2 fountains, there is an in-line puck chlorinator that don't use:
    What I think it is:
    A - out to fountains for sure
    B - out to bubbler for sure
    C - out to 4 returns?
    D - in or out to top of vacuum booster pump?
    E - in from main drain or skimmers
    F - in from main drain or skimmers (I could close one off and see which it is, if I'm right so far)
    G - small pipe flowing in or out from front of booster pump?
    H - out from sand-filter multiport snakes around back to SWG
    J - out to waste for sure, though I cannot turn the blue valve at all
    K - out from main pump to bottom of sand-filter multiport
    L - in or out from middle of sand-filter to bottom of multiport?
    M - in or out from lower on sand-filter to bottom of multiport?
    N - random 1" capped PVC sticking out of the ground--maybe plumbed for heater?
    So does the water come from the pool via E and F, through the pump, through K into the multiport, (something happens here with L and M), out the sand filter through H to the SWG, then back to the pool via A, B and C? Do I have the basic flow correct? Where do the booster pump pipes come into play, and how? Also, when it comes into the sand-filter, I understand that it comes in at the bottom, shoots through an internal pipe to the top where it is sprayed on the sand and filters thru, but I don't know how L and M fit into that process.
    Also, the two small black multiport levers between A-B-C and E-F will move to bottom, left or right, but will not move to "close" the main pipe coming into them. Is this correct, and why are they not "4-way"?
    If you've made it this far I thank you! This is the last piece of my understanding of a pool! (haha, as if).
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    38,290
    Re: Need help identifying plumbing...please?
    Answers in red:
    A - out to fountains for sure ok
    B - out to bubbler for sure ok
    C - out to 4 returns? yup, well maybe only 3 and the 4th from the booster pump.
    D - in or out to top of vacuum booster pump? That is out of booster pump to cleaner port in pool
    E - in from main drain or skimmers maybe you have 2 skimmers and a floor pipe somewhere. Since you only have 2 pipes at the pump, either the floor is plumbed to the bottom of one of the skimmers or the skimmers are plumbed together. You should be able to narrow this down a bit by playing with the valve.
    G - small pipe flowing in or out from front of booster pump? suction line for booster pump
    H - out from sand-filter multiport snakes around back to SWG yup
    J - out to waste for sure, though I cannot turn the blue valve at all yup
    K - out from main pump to bottom of sand-filter multiport yup
    L - in or out from middle of sand-filter to bottom of multiport? Depends on valve setting. While backwashing it is opposite of while filtering ... does not really matter which is which.
    N - random 1" capped PVC sticking out of the ground--maybe plumbed for heater? Odd. Could be an old line for the pressure cleaner (it is a little odd that the output of the booster pump is a big pipe.
    I think you are pretty close to understanding. The 3-way valves usually have stops to prevent you from closing the middle port and that could cause damage to the pump if it turned on.
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Thank you Jason! Big help. One more question, when I tried to deep clean my sand filter, I turned the filter multi-port to "closed", but when the hose water inside the filter got to about 8 inches from the top, I could hear it gurgling out the waste line. I didn't go anywhere else (back to the pool or to the pump). How do I completely close off the sand filter? My options on the multiport (clockwise) are Filter, Waste, Backwash, Close, Recirculate and Rinse. I fear I need to use the blue lever on the waste line "J" above, but it won't budge and I'm afraid to force it. Is the lever the solution, so I need to get it to close, or fix it?
    Thanks again!
    Sandra
    Aquapure SWG
    38,290
    Not sure. I would have thought that closed would close everything off. Maybe the spider gasket in the valve on the filter is leaking. The blue valve would be a back up.
