Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: NEWB-Cloudy pool with pics
    Total newb as this is my first pool. I've read through pool school and I'm currently slamming the pool. Started as dark green and immediately went to cloudy blue. Has been that way ever since (about a week now). Here are my most recent test results:
    FC: 10
    PH: 7.8
    TA: 120
    CYA: 30?
    Sand filter has been back washed when needed. I know I need a better test kit. I'm ordering one but in the mean time it only goes up to 10 FC so I'm keeping the level at least up to that. Any help is appreciated. It's been 90deg and I'm anxious to get this thing cleared up!
    25k gallon IG. Vinyl liner. Sand filter Pyrex meteor.
    Damascus, MD.
    Using Tapatalk
    Re: NEWB-Cloudy pool with pics
    Would help if I added the pics
    Damascus, MD.
    Using Tapatalk
    Jul 2010
    Philly
    332
    It's hard to give advice based on test numbers from strips. Especially on pools with vinyl liners. Without a solid CYA number it's not prudent to assume a SLAM level. I think what you're doing now is the way to go till you order a proper Test Kit. Keep dosing and filtering till then. Backwash when your filter pressure is 20 to 25% over clean pressure. Brushing and vacuuming always helps too.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    May 2014
    Lewisberry, PA
    93
    Hi Blackjack! Welcome to the forums! Good job reading through Pool School, getting a test kit and posting some results. However, the results you are getting with those strips ( I remember those!) are not what we consider reliable. They may be giving you something close, but in all reality, there are too many variables with the strips. My experience with them is that they are usually way off.
    Please read Getting Started: http://www.troublefreepool.com/conte...etting-started
    Add the following in your signature:
    The size of your pool in gallons
    If your pool is an AG (above ground) or IG (in ground)
    If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    Date of pool build/install, particularly important if less then a year old.
    Other significant accessories or options, such as a spa , SWG, or cleaner
    Congratulations! You have taken the first step in learning about how to maintain your pool. You took the correct first step in cleaning your filter and making sure it is working properly. We don't want to assume or do too much until you get your kit and we can get some accurate results posted. I wouldn't be surprised if your CYA is going to be way high. What type of chemicals have you been putting in your pool? If you are using any type of "chlorine" from the pool store ( dichlor, trichlor, powdered shock or algaecide) please stop using immediately!
    Hopefully you have read enough to know to use bleach (at least 6.25.%) unscented just plain bleach, to SLAM your pool. Going with your pool size, 25k gallons and a CYA (for now) of 50 targeting a Shock level of 20ppm you should add 4 gallons of 6.25% bleach.You can do this yourself using Pool Math: http://www.troublefreepool.com/calc.html
    I wouldn't do anything else until you get your kit. The next step would be to adjust your PH. But without knowing your current and accurate CYA level we should hold that off for now.
    Again, read through pool school, Slowly add in your bleach over your returns, wait for your kit and I'm sure one of our Moderators will be along with some great advice. I hope I didn't overstep my boundaries with the advice I gave, but think it will get you started. Good luck!
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
    Thanks. Well like I said I'm a newb but I'm learning. I started off with powder but I've lately been using bleach and liquid chlorine (12%). Is that stuff also ok?
    Damascus, MD.
    Using Tapatalk
    May 2014
    Lewisberry, PA
    93
    Yes! Be sure to use only half of the amount then (Add only 2 gallons) using 12%.
    Post a full set of test results when you get your kit. Keep filtering and back washing as necessary. You will have this under control in no time!
    TF-100 Test Kit
    Should I use 2 gallons a day until my test kit arrives?
    Damascus, MD.
    Using Tapatalk
    Feb 2014
    Houston, TX
    161
    I would suggest you raise your CYA to 60ppm after your get your test kit. Anything under 30ppm is hard to test for...you'll see. Also the more CYA you have the more it protects your chlorine from the sun (it does require a higher FC level though).
    Century B129, 3/4 HP, 1.5 SF,
    In-ground gunite 17,400 Gal, FNS plus 60 DE Filter
    Jul 2010
    Philly
    332
    Quote Originally Posted by consoleman View Post
    Why would you suggest that. Mr. Jack is gonna have to do a proper SLAM when his test kit arrives. If his CYA is indeed in the 30 range, he's at a perfect starting point for a SLAM. Besides, he's in Maryland and doesn't get that Texican sun you all get.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Jul 2010
    Philly
    332
    Quote Originally Posted by blackjack521 View Post
    Damascus, MD.
    Depends. It's your pool but you have to careful it doesn't build up. Test strips can bleach out with high Chlorine. When that happens, some folks think there's zero Chlorine. They add more and more. When they get their real test kit, it's like Holey Moley, how did my Chlorine get to 40 PPM. Me personally, I'd dump two gallons of 12% the first night and do an OTO dilution test mid-morning.
    The OTO test is a color match test for yellow. It has a yellow color bar that matches up to 3 to 5 at the top end. Higher Chlorine will deepen the yellow and as you go higher it will go to deepening shades of orange. Real high Chlorine will turn it brown. If you dilute your test water with equal parts distilled water you can get an approximation of Total Chlorine. So, if you dilute one part pool water with 3 parts distilled and the color matches up to 3 on the yellow bar that will get you a total of 12 TC. It's not accurate but it's ballpark enough. You times the color match by the number of water parts. A one to one dilution, you times by 2. Two parts distilled to one part pool, you times by 3 and so on.
    What ever you decide to do, it's better to chlorinate when the sun's off the pool. This way, a 100% of your Chlorine is fighting algae and not the sun and the algae.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    May 2014
    Lewisberry, PA
    93
    All good points. I was thinking to add the liquid bleach to get him started, find out exactly where his CYA level is with accurate readings and see where it is at . No need to get carried away if he needs to do a partial drain if the CYA is high. If it is low, than get him to slowly bring it up and start SLAM'ing! Any way you look at it, getting the FC up is not going to hurt.
    Casey's Avatar
    SW PA
    10,457
    Until you get reliable test results with your kit, everything is a guessing game right now. If you want to add a gallon of bleach a night to hold off the green monster, that is perfectly fine but anything more can run on the verge of being wasted. I would encourage you to wait until you get your test kit before you start adding copious amounts of bleach.
    Ok thanks! Kit isn't here yet but I've been bleaching just to stay on top of it. Pool is clearing up nicely. Hoping to add some DE to the filter today
    Using Tapatalk
    Jul 2010
    Philly
    332
    Go slow with the DE and make sure you keep an eye on the pressure.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Feb 2014
    Houston, TX
    161
    I just tried CYA at 40ppm when it was around 90deg outside. That ate my chlorine up like a fat kid loves cake. 20-30ppm of CYA is really only 2-3ppm of FC more. Everthing is bigger in Texas even the CYA levels.
    Ok I'll go slow with it. Last night I shut the filter off and came out this morning and I could see the bottom of the deep end! Turned the filter back on and back to cloudiness.... I assume that normal as the return stirs things up?
    Using Tapatalk
    Ok got my test kit it's a Taylor. Here are my readings
    Fc 5
    Tc 5
    Ph 7.2
    Ta 10?
    Ch 12
    Cya 20-30
    Just added 1 cup of de (half cup at a time) and my filter pressure went up 1 psi. Also added some more bleach to bring that fc back up to shock level. Here's what it's looking like now
    Using Tapatalk
    May 2014
    Lewisberry, PA
    93
    Good going Blackjack. It may take a couple times at first until you get to know your kit better. How did you do the CYA test? Did you hold it at waist level in direct light? This may be the most difficult test to get right. Not that it is hard but it might take a couple times to figure it out. Was the water in the tube cloudy? You really need to concentrate on the black dot and make sure it completely disappears. You should get an exact reading. Not 20-30 but something definite. This is important.
    Maybe this video will help: http://www.youtube.com/watch?v=Nxaqo...9Y_YYNAeLtUr1g
    TA at 10 is suspect also. For now, let's concentrate on the CYA, FC,CC and PH.
    Do these a couple of times, check your results and post them again. You are on your way! Keep going.
    TF-100 Test Kit
    The water for the cya test was not very cloudy I filled the tube up all the way to the max and could still barely see the dot. Top of the tune was 30. Since I could still kind of see the dot I assumed it was more like 20. I think TA was supposed to be 100. I'll have to look at the test kit again, but 10 drops is about what it took to change the color of the water. I'm new so it's hard to determine what exact number of drops changes it. I'm also confused about the FC test. My kit only goes up to ten but I need to be higher to shock it. Do I dilute the test to measure higher levels?
    Using Tapatalk
  20. Back To Top    #20
    May 2014
    Lewisberry, PA
    93
    Make sure you are mixing the reagent properly and try the test again. You may just have low CYA but its better to test a couple of times and be sure.
    TA was probably 100. Not too concerned with the TA just yet. SLAM'ing the pool will throw off the test. We need to concentrate on the CYA level first. PH level next, then get your FC up to SLAM level and keep it there. But first things first. CYA level is extremely important.
    Do you have a speed stir with your kit or are you mixing manually?
    TF-100 Test Kit
