Thread: Looking for a Custom Pool Calculator that prints a table just for my gallon volume.
    May 2011
    Venice - Sarasota Florida
    30
    Question Looking for a Custom Pool Calculator that prints a table just for my gallon volume.
    Hi,
    I want to make a paper (computer will not be available) guide for adding chemicals specific to my pool gallon's. It needs to include tables for FC, TA, PH, etc that will guide in the amount of Chlorine, Acid, bio-carb to add to the pool. This will be for a employee that needs to be as simple as possible. Does anyone know a website or excel file that can produce this?
    Thanks
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Looking for a Custom Pool Calculator that prints a table just for my gallon volum
    You can input your pool volume into PoolMath and create an excel table based on the "effects of adding chemicals".
    Note the disclaimer about pH changes.
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    I keep notes in my test kit that say "1 jug of bleach adds 4 ppm FC" and "At CYA = 40, FC target is 5 ppm, minimum is 3 ppm", "At TA = 80, 3 cups MA reduces pH from 7.9 to 7.5"
    May 2011
    30
    Thanks all for your responses. I think a custom table with stealing some good info from the Hayward guide will work great.
    Jun 2014
    Michigan
    62
    I added columns to JesseWV 's Graphical Pool Test found here @ TFP that keeps track of what I did for what issue and how it impacted the pool. From there you simply set the print window to that log and there ya have a paper trail.
    Here is the link to his Graphical Pool Test... http://www.troublefreepool.com/threa...l-spreadsheet)
    20K gal, Fiberglass, 1.5 hp Century Pump, Sta-Rit System 3 Model PLM-100, 100 SQ Foot. Inline Frogger Chlorinater Mineral pack removed, adjusted the Chlorine pac to put in my own when on vacation. Liquid Pool Sanitizer,, BBB style.
