If you haven't already, now is a good time to start adding DE to your sand filter to help clear the dead algae.
Oh, and from the size of that hairball, maybe you will find a dead cat at the bottom when things clear up!
Order one of the nice liquid filled gauges from Dave.
I think I'd wait since you're only supposed to add enough to raise the pressure by 1 psi it would be best to be accurate with that. In the meantime the filter will still be working so it's not like you're losing anything.
Ok, will do. I was hoping for the pool to be swimmable by the 4th, but it looks like the algae may have Other Plans for me.
Don't give up hope. That is still possible but I wouldn't plan a pool party until you're certain.
You've made a lot of progress!
Algae Exterminator's Log - Day 009, Entry 002: We got hit with a big nasty storm. Luckily, my roommate was home to test the water for me. Post-storm, I've still got 10 FC and 1 CC. I asked him to hit it hard with two jugs of bleach just in case the water tries to pull a fast one on me. I'm going to Walmart to replenish bleach reserves today after work. More to come!
Quick question: Is there any merit to super-duper-chlorinating the swamp at this point? For example, if I were to come home today to 10 FC and dump 10 jugs of bleach to raise it to 30. My gut says this would be the final blow against the remaining algae, but I'm not confident it would be as effective as I think.
I've planned a tentative pool party, as in, the pool aspect of the party is up in the air
You don't want to go too much above your shock level because you don't want any fading or damage to your liner and pool equipment.
