Thread: OCLT test question
    Jun 2012
    NW CT
    77
    OCLT test question
    I just read the oclt section how to perform. It didn't really answer my question directly so I thought I would ask.
    Does the oclt need to be done at an FC of shock level or can it be done from any FC level? The directions say to just test it after no sun and at least 30 mins after chemical additions in the evening. Doesn't say it needs to be at or above shock.
    I am just wondering because I was thinking of letting my FC drift down to normal levels today and test tonight then in the morning. I just wasn't sure if the test would be as accurate at let's say FC of 7 tonight vs an FC of 18 for my shock level. Just wondering, maybe it doesn't matter.
    Thanks.
    43x21x54" Sharkline/Wilbar Above Ground with hopper, 26,000 Gal
    Sta-rite 22 in sand filter with Zeosand removed reg pool sand installed, Sta-rite 1.5 hp pump, Poolsmart Climber Robot, TF-100 Test kit, poolskim, hard plumbing with second return added for poolskim, fafco solar heater, Luiquidator
    38,301
    Re: OCLT test question
    That is slightly controversial if you get into the chemistry details
    The OCLT process was written with the assumption that you are in the SLAM process and thus your FC is a shock level. So the 1ppm loss is small relative to the high FC level.
    You could do the OCLT at normal levels, but personally I may not consider a 1ppm loss as a pass and would prefer it to be 0.5ppm or less.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I thought at "normal" FC levels there should be no loss at night. So anything more than .5 would probably be something growing. I actually use the OCLT test at normal levels to test my auto-chlorinator function (how much FC it's adding).
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Jun 2012
    NW CT
    77
    I will keep it at shock level for tonight's test then thanks!
