Results 1 to 20 of 20
Thread: Time to add CYA and Chlorine for the first time ever...
    May 2014
    Winnipeg
    10
    Talking Time to add CYA and Chlorine for the first time ever...
    YESSSS! Another hour and pool will be filled. This website and the moderators/knowledge base is just awesome! It has helped so much with the site prep and general confidence level.
    I just tested with the following results:
    FC=0
    CC=0
    TC=0
    pH=7.2
    TA=80
    CH=100
    CYA=0 (assumed this number because it is brand new water from city, is that ok?)
    Once the water fill is done and the pump/hoses are verified I believe I will need to add the following based on The Pool Calcalator.
    1. Add 48 oz of my 8.25% bleach
    2. Add 32 oz of CYA stabilizer using the sock in front of outlet method
    Does this look correct?
    Also, I have some hand me down Sun brand conditioner to use but it has got to be atleast 5 years old. Does it go bad or do you think that will be ok to use?
    Did I say this site was the best?! I feel like Walter White using my new TF-100 test kit and SpeedStir
    First year with AG Vinyl Summer Escapes 19' x 54"
    Pool Size: 8000 Gallons
    Pump/Filter: Retrofitted Intex 2500-GPH B-Filter Pump
    Test Kit: TF-100 and SpeedStir
    Bleach: 8.25% Chlorine
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Time to add CYA and Chlorine for the first time ever...
    What you have should work (are the ingredients high 90's % CYA) but don't put all the CYA in at once. Undershoot your goal then slowly bring it up. You don't want to overshoot
    Support the site
    May 2014
    Winnipeg
    10
    OK, so I should add about 24 oz and wait 4-5 days to retest and add a bit more if needed? The container doesn't say actual % of CYA.
    Should I add the bleach as soon as the pump is circulating?
    How long should I leave the pump running 24 hours a day for? I think eventually it will only be needed for 4 hours a day.
    38,524
    Add the 32oz ... you want to have the CYA at 30ppm as a minimum anyway. Verify it a week after it dissolves, but assume you are at 30ppm to determine FC levels.
    Add 2ppm of bleach when the pump fires up, 30 minutes later check and adjust the pH.
    Technically there is no reason to run the pump 24/7 at all. But you may want to for the first day to help get teh CYA dissolved. Squeezing the sock speeds that up.
    May 2014
    Franklin, NC
    9,197
    Quote Originally Posted by Kookookachoo View Post
    no need for 24 hour circulation unless you are conducting a SLAM.
    Even without the pump running, you can add some bleach and brush the pool to get a little circulation. You don't want to let anything start to grow.
    The SUN website says "Add 1 lb. per 3,000 gallons to raise stabilizer to the initial level of 40 ppm". Pool Math says for 3,000 gallons you need 16 ounces CYA to go from 0 to 40, so I think you got 100% CYA there. Your idea of 24 oz then wait to test should,work.
    Support the site
    May 2014
    Winnipeg
    10
    Thanks everyone. I've added the CYA and am going to check and keep my FC at 2PPM for the next week, then check the CYA level.
    Question about the CYA test in my new TF-100 kit though. The instructions say to fill the red-capped CYA mixing bottle to the bottom of the label with pool water, then fill the bottle to the top of the label with R-0013. The red-capped mixing bottle in my kit doesn't have any label on it. Did they miss that? Can someone send me a pic of theirs or let me know the approximate ratios?
    Thanks
    May 2014
    Franklin, NC
    9,197
    Thanks
    Shoot an email to TFTestkits@gmail.com they will take care of it for you. You have a week before you need to test.
    Support the site
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Have a look here:
    http://tftestkits.net/CYA-Mixing-Bot...F-100-p25.html
    Click on the picture to enlarge
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Schroedz's Avatar
    Apr 2014
    Martinsburg, WV, USA.
    87
    Koo. I checked mine and it's 15mls of pool water to the bottom of the label and 15mls of R-0013 to reach the top of the label.
    Here's a pic of mine next to a tape measure. Hope it helps
    Schroedz.
    21,000 Gal, 16' x 36' Grecian In-Ground Vinyl Pool,
    Built 1981 ~ Reno/New Liner June/July 2014,
    Hayward Pro-Series 25" 300lbs Sand Filter With Zeobrite Media (SM2506T),
    1 HP Haywood Dual Speed Super Pump (SP2607X102S).
    TFT-100 & Speed Stir ~ Aquabot Xtreme Robotic Cleaner.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Thanks
    Yes, the label it was missed.
    Ratio is 1:1
    Oct 2013
    Chapin, SC
    1,141
    What does the test vial look like? That's more than double the reagent required to perform a cya test with the k-2006 test kit!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Schroedz's Avatar
    Apr 2014
    87
    Quote Originally Posted by timerguy View Post
    Koo has the same kit as me. The TFT 100, so the measurements are the same.
    Schroedz.
    Oct 2013
    Chapin, SC
    1,141
    That wasn't the question.
    Schroedz's Avatar
    Apr 2014
    87
    Sorry.
    Here's the vial
    Schroedz.
    Oct 2013
    Chapin, SC
    1,141
    Thanks, now I understand why so much r-0013. That's a BIG vial!
    Schroedz's Avatar
    Apr 2014
    87
    Your welcome. Yeah it's a bit big at 4 1/2 inches long and 3/4 inch wide. I should of took the pic with a tape measure next to the vial. >.<
    Schroedz.
    May 2014
    Winnipeg
    10
    Thanks so much guys and gals!
    Schroedz's Avatar
    Apr 2014
    87
    Your welcome.
    Schroedz.
    May 2014
    Winnipeg
    10
    It has been 7 days following this method and I'd like confirmation that I'm on the right track. I've been testing FC and pH daily and most days on average I've been reading FC at 0.5 to 1 so I've been adding between 6 to 18oz of bleach to bring it back up to 2. On day 1 I added 3 cups of CYA to slowly reach my goal of 30. On day 4 I measured a pH of 7.2 so I added 10oz of Borax to reach my goal of 7.5. The water has been very clear throughout.
    Today my readings are:
    FC=1.5
    CC=0.5
    TC=2
    pH=7.5
    TA=70
    CH=100
    CYA=24
    I've just added 18oz of bleach to aim for 3ppm and 6oz more of CYA.
    Does this look alright? The TF-100 testkit says to keep a consistent chlorine level of 2 so I'm going to aim for 3 because it seems like my pool eats 1 to 1.5 ppm per day. Should I aim higher?
    Question about the TA test. When adding the R-0009, am I looking for the first instance of a color change to red or for it to change to red permanently? It normally takes another 3 or 4 drops for it to stay red permanently.
    Should I be concerned that the CC is 0.5?
    Thanks!
  20. Back To Top    #20
    38,524
    Now that your CYA is higher, you need to maintain higher FC levels. See the chart in the handy reference section of Pool School.
    All tests are done until the last drop causes no further color change and that last drop does not count.
