Results 1 to 9 of 9
Thread: Advice Needed For Purchase of New Pump and Filter (Pics Included)
    Jun 2014
    Delray Beach, FL
    13
    Question Advice Needed For Purchase of New Pump and Filter (Pics Included)
    Hello forum!
    I've been lurking around here for a few weeks and have found so much information. As such I will start by simply saying Thank you to all who contribute . . . and to those of you who post pics of your beautiful and sometimes ridiculous pools!!
    Now onto my query. We moved into a fixer upper about a year ago. The one requirement of the home was it had to have a pool or room for one. We lucked out and have a fantastic pool IMO, which has hosted many parties. My issue started with constantly having to fill the pool up with water, which I chose to blame on evaporation in an effort to not admit to needing a new pump and filter. A year later and the situation can no longer be ignored; the situation being that both the pump and the filter are leaking. I don't want to patch the problem, I just want to buy new equipment so I don't have to deal with it for a long time.
    Initially I thought bigger was better when it comes to pumps (2hp), but thankfully I believe that is not the case due to reading this forum. The one issue I do have is the suction on the vac is perfect for my "Pool Cleaner 4 wheel," but the suction seems to be too hard for the skimmer because even if the pool level fills up half of the skimmer hole, the skimmer will suck the water down so fast that air will travel through the pump (I assume I may need a pump that changes pressure?)
    The pool is about 14,500 gallons (I think based on an online pool calculation). Below ground concrete with the equipment about 1-2 feet down hill from the surface. We live in south east Florida. Has a separate vac and skimmer. I believe there are also four in takes at the bottom of the deep end. We do have a water fall, which has flowed perfectly with the current pump power, but I'm not sure as it has a cracked pipe under the brick so I haven't used it much since it leaks (an easy fix that I just need to spend the time on). The pool also has four bubble jets (jacuzzi) that hook up to a separate pump. Lastly, there is an open pipe on the side, which I have no idea what the purpose is for. Please see the pics below for a better understanding.
    In short, I have the following questions:
    1. Do I need both pumps? I assume yes since I don't want to always run the bubble jets.
    2. What pump and filter combination do I need? Remember I have an issue with pressure differences from VAC and Skimmer.
    3. Do brands matter? I feel I'm sold on pentair, but can easily be swayed.
    4. A huge problem is the amount of dirt and sand the dogs bring in the pool. Is there a filter that can handle this without being torn to shreds?
    5. Is this stuff that complicated to install? I feel I can get it done.
    6. Side question, I have two pool lights that used to change colors but no longer rotate through the colors. Any advice on getting these working again? I don't have an issue with draining the pool to fix it.
    7. The final picture is of a open pipe on the side of the pool . . . what is this for?
    8. If there is a question I'm not thinking of that you see in the photo's or while reading, please chime in.
    My goal is to have an affordable system that is reliable and will get the job done. I really am looking forward to no longer sticking the hose in the pool for long periods of time, and if I can save on energy costs, that would be FANTASTIC!!! Again, the pump currently sucks too hard on the skimmer but just right on the vac . . . although the vac has gotten slower.
    Here are the pics for better details.
    Overall pool shots:
    Current Equipment:
    Pump Valves: The top one I believe is for the waterfall, the switch on the right takes me from vac to skimmer, not sure what the bottom left is for
    This pump is for the jacuzzi jets around the stairs/seating: The current primary user of the pool as you can see is the american bulldog great dane mix AKA Odin.
    Current pump handling the vac and skimmer:
    Current Filter:
    What I believe to be four intakes on the bottom:
    Current Electrical Set up: Is this fine?
    Pic of the Waterfall in the event it is helpful to analysis:
    Lastly, I have no idea what this small pipe is for (dead center of the pic). The only think I can come up with is it keeps the pool at a certain level to help keep it from overflowing. If this is the case, can I cover it for the time being since I'm losing so much water anyway?
    Casey's Avatar
    SW PA
    10,461
    Re: Advice Needed For Purchase of New Pump and Filter (Pics Included)
    Welcome! I would suggest a 1HP 2 speed but the issue you are faced with wanting or needing 2 pumps? I'm not sure. I'll let someone else answer that. As far as filters go, which ever you decide (I love DE myself as they filter the best) get the biggest filter you can afford! You just can't get to big of a filter.
    As for your skimmer sucking air, throw a tennis ball in the skimmer and call it a day. It will stop any vortexes from forming and the pump from drawing air from said vortex.
    Nice pool and love the dog swimming! I miss my dog as she was my swimming buddy.
    Jun 2014
    Delray Beach, FL
    13
    Thanks!!!
    A tennis ball . . . I love this forum, how would I ever have thought of that!!
    Anyone else want to weigh in?
    Jul 2011
    Perrysburg, OH
    88
    Nice pool! So main problem is pool is leaking requiring constantly filling up with the hose? Why do you think pump and filter is the cause? I didn't see noticeable signs of leakage in the pics...
    16 x 32 inground vinyl pool (21000 gallons) (new liner installed 2014)
    Hayward max flo pump w/ 1 HP AO Smith motor (new motor 2014)
    Hayward C1200 cartridge filter (new 2014)
    Hayward H150 heater
    Jun 2010
    Round Rock, TX
    20
    Regarding the lights... Obviously I don't know if yours are the same as mine, but mine have 2 modes (color change, and constant color). To change modes, I just have to flick the switch off for about a second, then turn them back on. If they are turned off for more than about a second, when they are turned back on, they will remain in the same mode they were before. If you already knew that, just ignore me
    I also had an issue with one of the lights color wheels being stuck. Turned out that one had a bad motor likely due to a power surge. I was able to find the part on amazon and replace it. You shouldn't have to drain the pool to work on the lights. When you remove the screw, there should be enough wire attached that you can pull it completely out of the pool to work on it.
    15K gallon IG gunite with waterfall; 1.5 HP Pentair WhisperFlo pump; Pentair CC200 (200 sf. cartridge filter); 3/4 HP booster pump; Polaris 280; Levolor Electronic Water Leveler
    Jun 2014
    Delray Beach, FL
    13
    Quote Originally Posted by Sminor View Post
    I can visibly see it leaking while the pump is running. Doesn't matter how tight.
    Quote Originally Posted by julio View Post
    I didn't know about the light switch! They were already installed when we bought the house. Can you explain in more detail please?
    Great responses guys. Does anyone have a suggestion for a pump and filter? I got Casey's, which I will go with if no one else has any suggestions.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Why not just get a replacement cartridge and seal, and swap out the motor for a 2-speed. Looks nice.
    Jun 2014
    Delray Beach, FL
    13
    Thanks for the advice guys. What I'm really looking for is a new filter and pump suggestion; no parts or suggestions of the like (although appreciated). I simply want something new that I can install myself.
    If anyone has any feedback/suggestions in that regard, it would be greatly appreciated. It may help to number the answers in correlation with the questions. Thanks again guys.
    Jun 2014
    Delray Beach, FL
    13
    Anyone else want to weigh in? I'll probably buy the pump and filter on amazon tonight.
