Thread: tF100 Options?
    Jun 2014
    Edmond, Oklahoma
    42
    tF100 Options?
    Buying my first TF-100 today for a new pool currently under construction. I am looking at adding the XL option. I'm kind of a nerd and see a lot of unnecessary extra testing while I am getting my bearings. I can't tell by looking at the site which of the reagents are increased with the XL option. Is that posted somewhere and I am just missing it? If not, can someone here tell me which reagents come with the XL?
    As for the SpeedStir. I brew my own beer and use a magnetic stir plate to grow brewer's yeast. Is there something special about the SpeedStir? Or would I be able to drop a 1" stir bar (I have several) in my test tube with the reagent and use that?
    Also, for the extra stir bars if I go with the speed stir, will any standard 1" stir bar work? Like I said, I have several for use with my other hobby.
    12,500 gallon, in-ground Grecian Rectangle (vinyl liner). Installed June 2014. Sand filter, SWG for chlorination. TF-100 test kit.
    Located in Edmond, OK
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: tF100 Options?
    The XL comes with double the powder and drops for the FAS-DPD chlorine test. If you're clearing a swamp, you'll need it. If you're OCD, you might as well get it and save shipping later. The other reagents are readily available in local pool stores if you run out; the FAS-DPD test is almost unheard of in stores.
    If you already have the stirrer, use it. The speedstir has a lip that keeps the vial centered, that's about it. I ordered spare 8*25mm stirbars from a brewer's supply on eBay and they look exactly the same. So you're set.
    Jun 2014
    Edmond, Oklahoma
    42
    Re: tF100 Options?
    Thanks Richard. Does the TF-100 come with a vial for test water, or is that something I would need to order separately?
    Richard320's Avatar
    Jan 2010
    18,966
    Re: tF100 Options?
    It has everything.
    Jun 2014
    Edmond, Oklahoma
    42
    Re: tF100 Options?
    Cool. One more followup. I am installing a SWG and eventually plan to add borates to the water. Will the standard salt strips and the borate test strips be sufficient to keep track of those?
    Richard320's Avatar
    Jan 2010
    18,966
    Re: tF100 Options?
    Quote Originally Posted by JCarsten View Post
    I have no idea. I use neither, so I don't test for them.
