Thread: Pervious Concrete Pool Deck
    Lizbethmcq's Avatar
    May 2014
    Parkesburg PA
    46
    Has anyone used pervious concrete for their pool deck? Internet research shows that "it can be used" for pool decks but I'm not finding any examples of this being done. Wondering what anyone who has done this (if there is anyone) thinks, are you happy with it, any issues? Hoping this may be a way around doing storm water management for my pool build, or at least reduce the size of the system I would have to put in. Thanks!
    Liz
    Liz
    17,500 gal, IG Trilogy fiberglass sport pool 43'8"x16', Jandy Cart CS Ser filter, Jandy Pro Ser+ 1.5 HP pump, Nature 2 Fusion Soft SWG (mineral removed), TF-100 test kit w/ SpeedStir, Dolphin Oasis Z5 robotic cleaner. Maax Spa 481 (455 gal)
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pervious Concrete Pool Deck
    Have you actually seen and walked on pervious concrete? If you had I doubt you would be thinking about it. It is rough -- no make that extremely rough.
    Attached is a brochure on pervious concrete. http://www.scvurppp-w2k.com/workshop...0thru%2020.pdf
    I am familiar with Banister Park in Fair Oaks, CA shown on the brochure. That parking lot is not something you want to walk on in bare feet, let alone run and jump into a pool from. I get concerned when my children ride their bikes on it.
    In addition, one reason to have concrete is to channel water away from the pool area so it doesn't affect the pool structure. The more water you keep away from the pool structure the better your pool.
    I don't think you would be happy with pervious concrete.
    Lizbethmcq's Avatar
    May 2014
    Parkesburg PA
    46
    Thanks gwegan, yes I am aware of most pervious concrete being quite rough, but if you use a fine rounded aggregate that no longer is a factor. The bigger problem seems to be the size and type of job. Most pervious contractors do large jobs justifying large batches of material this job would be too small and more specialized than just a driveway or sidewalk. I was curious about the water getting in and around the pool if that was an issue and it sounds like it might be.
    There is a pool near me with a pervious deck, I'm going to contact that homeowner and see if I can go take a look at it.
    Appreciate your feedback.
    Liz
