Thread: Dissolving Cyanuric Acid at Higher Temperatures
    Jul 2013
    western new york
    62
    Is CYA more soluable at higher water temps? Does anyone know how soluable CYA is?... Is it possible to dissolve several pounds of granules into a 5 gal pail of hot water and create a super sat solution of it? Then keep it stored until needed.
    15k gal inground Viking fiberglass pool; Hayward Variable 1.5hp pump (Maxflo VS); Hayward swimclear 325 sg ft cartridge filter; Raypak 206A 199k btu nat gas heater; Aquabot Bravo robotic pool cleaner
    Re: Dissolving Cyanuric Acid at Higher Temperatures
    Yes, but only just a tiny bit. You will never get a useful amount dissolved in a bucket/pot of water even with lots of heat.
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    I just put in 4lbs of CYA from Home Depot. It dissolved in a sock in a day and a half.
    25k IG vinyl SWG Haywood 4830de 1.5hp TF-100
