Thread: salt water system
    Jun 2014
    conway/sc
    1
    Unhappy salt water system
    I have a sws that tells me that I need salt when I don,t also it doesn,t produce salt. what is the problem with this system?
    Re: salt water system
    Welcome to TFP!
    Nothing you mentioned sounds like a problem. Perhaps you meant that it doesn't produce chlorine?
    In any case, for us to be able to help you, you should post a full set of water test results.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Welcome. Also, what type of SWG do you have? Please add a signature line to your profile listing your pool type/size and equipment.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    An SWG (Salt Water Generator) does not generate salt, it generates chlorine from Salt Water passing through it. Yours is telling you that you need salt, and the fact that it is not generating chlorine means you probably do. Have you measured your current salt level?
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
