Thread: Using PVC glue and primer in the rain
    Jan 2014
    Fredericton, NB, Canada
    130
    Hi guys...looking for advice again. I am almost finished plumbing my pool and all my equipment and fittings but have 2 more joints to glue outside. I want to finish it up today, but it's raining here. Can I still use the PVC primer and glue in the rain (there will be drops of water on the connecting pipe and fittings no matter how hard I try to dry it), or am I wasting my time and won't get a proper joint if there is any water at all?
    18' x 36' IG Vinyl Kidney Shape, 20K Gallon, Hayward ProLogic PLP4 Control with T-15 SWG, ColorLogic 4.0 LED Light, Hayward TriStar 1 HP Full Rated Pump, Hayward Swimclear 325 SQ FT Cartridge Filter, Raypak 117000 BTU Heat Pump, TF100 Test Kit.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Using PVC glue and primer in the rain
    Mark
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree use the blue rain or shine pvc cement it will work fine
    Jan 2014
    130
    Thanks guys...shortly after I posted the thread, it stopped raining...so I quickly finished up. My pump is now RUNNING for the first time ever!!!! No leaks at all that I can see! Super excited!
