Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Algae separating after flocculant
    Mattjames's Avatar
    Jun 2014
    Harpersville/Al
    16
    I have an in ground pool with a vinyl liner. 42,000 gallons. I have the chemistry correct. The pool is green. I added 7 lbs of shock, cal hypo,and waited 1 hour (this is what the directions for the Flocculant say to do)and shut the pump/filter off. Added 2 bottles of Revive( a flocculant) it's been 36 hrs and half of the algae is on the bottom like it should be, but half is floating on the surface. This is the second time this year it has done this. I'm just now starting my pool by the way. A week ago I did the same process with the same results.the first time this happened I tried turning on my pump to let the filter remove the surface algae, but it went straight through my filter and clouded the pool back up. So now I'm back to the separated algae. I also bought a net for algae and it doesn't work. It just pushes it around the pool. This is my 7th year cleaning this pool. I'm not an amateur and have never seen this before. Has anyone seen this before? What did you do? Any ideas? Oh and I have a sand filter.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Algae separating after flocculant
    Welcome to TFP!
    There's a couple of things here that we need to know:
    Are you doing your own testing or relying on a pool store for that?
    What are your test results?
    Has that filter ever been deep cleaned?
    Algae problems are NOT a filter problem, they are a chemistry problem.
    If you want, we can help you to solve this green pool thing. However there will be some things that you will need to do.
    You probably don't want to hear this, but there will be a bit of reading involved. Please do read these sections of Pool School:
    http://www.troublefreepool.com/conte...ater-chemistry
    http://www.troublefreepool.com/conte...efeating-algae
    http://www.troublefreepool.com/conte...at-is-tfpc-bbb
    What we try to teach here will help you to care for your pool in the least time consuming, least expensive methods available. Many of us have gone through what you are experiencing, and have learned that the pool store is not you friend.
    Mattjames's Avatar
    Jun 2014
    Harpersville/Al
    16
    Thanks for the welcome! I went out and bought some liquid bleach from the store, a lot cheaper than a pool place. I've been using super shock @$4 a lb. it wasn't easy on the wallet. But anyway I'm in the SLAM process now. I had to put 24 96oz bottles in right off the bat. This is a HUGE pool. They are only 2.75% chlorine. I'll go further for the 6% in little while. I'm gonna download tapatalk and try and get some pictures on here. A lot of the chlorine settles to the bottom after an hour so common sense says to brush every hour. It must be that confounded floc. Thanks for the help. I'll keep y'all posted.
    30,431
    Hi, Matt, Welcome to the forum.
    Nope, Chlorine distributes evenly in pool water (your pump is running, right?) VERY quickly and does not settle but is suspended evenly throughout the column shortly (say 30 minutes or so after it is introduced.)
    Have you read the ABC's of Pool Water Chemistry yet?
    Mattjames's Avatar
    Jun 2014
    Harpersville/Al
    16
    first round of chlorine for a 42000 gallon pool.
    Yes I have it running constantly. I can see the algae settling. I put in a lot of flocculant. Because I intended to vacuum it out before I joined this wonderful forum and learned about the SLAM process.
    Rectangle In-ground 49,725 gallons, vinyl liner
    Hayward sand filter
    Hayward 1 HP Super Pump
    10+ years old
    Mattjames's Avatar
    Jun 2014
    Harpersville/Al
    16
    I am doing my own testing the results before the SLAM are;
    Hardness: 250
    Total chlorine:0
    FC: obviously 0
    Ph: 7.4
    TA: 80-90
    CYA:30
    TC now: 15 or more, off the scale.
    FC now: 12
    Hayward sand filter
    10+ years old
    30,431
    Good Job, Matt,
    Your on your way. You need to be able to test that Chlorine VERY accurately so you need another chlorine test kit called an FAS/DPD chlorine test.
    Re-check your math on the pool size. Obviously, just guessing but your pool looks to be a bit smaller than 42k
    While your waiting on your FAS/DPD kit, it is important you replenish again and again to put your FC back at that 16 ppm SLAM value
    You have netted out whatever solid debris you can, correct? Chlorine alone along with a good working filter and vacuuming will get your pool crystal clear. Keep that SLAM article at your fingertips and follow it precisely.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to the forum Matt SLAM it till it's blue !!
    Solar Blanket, Well Water, Borax Added. 76
    Mattjames's Avatar
    Jun 2014
    Harpersville/Al
    16
    Thank ya, and I will and post pictures along the way. I'll get more up tomorrow as it looks about the same as earlier right now. I went and got some concentrated Clorox a minute ago.
    Hayward sand filter
    10+ years old
    Mattjames's Avatar
    Jun 2014
    Harpersville/Al
    16
    Had some chlorine loss this morning, 8 ppm. I put 3 tablets in last night before I went to bed to help a little.
    Before brushing
    After brushing
    Hayward sand filter
    10+ years old
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Be careful with the tablets, they are about half CYA and can quickly push you into a stabilizer range you don't want to be in. Tablets have their place, but a SLAM is not usually one of them.
    Support the site
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Quote Originally Posted by tim5055 View Post
    What he said. Depending on your CYA level they might be nice to use when going away for a few days or vacation but they can add CYA faster than you want if you're not watching the level.
    Please add the following information in your signature. If comes in handy for answering questions as the person doesn't have to go back looking for the info , , thanks.
    The size of your pool in gallons
    If your pool is an AG (above ground) or IG (in ground)
    If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    Date of pool build/install, particularly important if less then a year old.
    Other significant accessories or options, such as a spa , SWG, or cleaner
    Mattjames's Avatar
    Jun 2014
    Harpersville/Al
    16
    Thanks for letting me know about the tabs. I took them out this morning and won't put them back until I'm done SLAMing. My pool is 40'x 25 1/2'. 10' deep end and 3' shallow.
    How do i put a signature? Do I have to make a certain amount of posts before I'm allowed? or do I need to be on a desktop computer?
    For now the filter is a Hayward sand filter.
    1 HP Hayward Super Pump.
    No Clorinator or SWG.
    This pool is at least 10 years old. I've had this house since 2007 and the pool was run down then. I had to put in a new liner, pump, and filter when I bought the house. The pump has to pull up hill (about 3 ft above pool water level) the guy that built this house was a genius, a real Einstein.
    Hayward sand filter
    10+ years old
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Might be easier on a desktop but it doesn't make a difference as far as the system letting you. You just need to click on "settings" in the upper right of this screen just under "pool school". On that next page over on the left under "My Settings" in "Signature" and that will pop up a box to add the info.
    Just makes it so much easier on all of us
    Casey's Avatar
    SW PA
    10,457
    As Dave mentioned, grab a FAS/DPD chlorine test and you'll be better able to track your FC, up to 50ppm.
    You have to keep on the SLAM. Maintaining the SLAM level is the most important as the algae is going to keep eating up the FC. The more you add and keep at SLAM level, the faster you'll kill it. FLOC's are mainly a waste of money, a pain in the rear and can clog a filter. Very seldomly will you hear them recommended here.
    Mattjames's Avatar
    Jun 2014
    Harpersville/Al
    16
    Thanks Frog I'll get that info put on my signature. I will keep up that chlorine level until its clear. Too far in to let it go backwards!
    Day 3:
    FC overnight loss: 5 ppm
    Before brushing
    After brushing
    Hayward sand filter
    10+ years old
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Getting really close now!
    Sep 2011
    Lumber City, Ga
    9
    Making good progress. Keep it up
    24x48 Atlantic AGP
    18" Hayward Sand Filter
    1 HP Hayward Powerflo LX
    Mattjames's Avatar
    Jun 2014
    Harpersville/Al
    16
    ok, its at the point where im trying to clear it up. i read somewhere on here that i can add Diatomacous Earth to my sand filter to make it more efficient. how much should i add? i cant find the article i read.
    Hayward sand filter
    10+ years old
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Quote Originally Posted by Mattjames View Post
    http://www.troublefreepool.com/conte...-a-sand-filter
