Results 1 to 7 of 7
Thread: Brand new DE Grids/Still green algae
    Jun 2012
    St Pete FL
    45
    OK so I was taking care of a friends pool and they wanted to save by having me do it every other week. Finally told them NO, all or nothing. Got algae cleaned up (so I thought) and also was finding DE coming back into system. Had torn and broken grids. Cleaned grids while waiting for new ones to arrive. 4 days later went to put new grids in and old ones were covered with green algae again. Figured after putting in new grids, cleaning EVERYTHING I could see and recharging the system I should be good to go. It has been 2 weeks now and I still am getting green in the pool. Chemical and numbers are all good. I have brushed, vaccumed and backwashed constantly. I cleaned the returns, skimmer and lights. Is there something, somewhere I am missing that could still be holding onto some algae????
    5,000 gal Fiberglass paper cartridge filter, autochlorinator, BBB
    20,000 gal Pebble Tec paper cartridge filter, BBB
    15,000 gal Pebble Tec, DE filter, autochlorinator, BBB
    20,000 gal Pebble Tec, sand filter, BBB
    38,548
    Re: Brand new DE Grids/Still green algae
    Algae is a chemistry issue, not a filter issue. Post up a full set of test results and let us judge "good".
    You need to follow the SLAM process to clear the algae.
    Jun 2012
    St Pete FL
    45
    I have SLAMMED it
    38,548
    If the water is not clear then you should not have stopped the SLAM process. Can you confirm you followed the SLAM process defined in Pool School?
    Jun 2012
    St Pete FL
    45
    Yes I followed your technique and the water was and is clear. Finding the green on some walls, ports and floor. Not completely covered but in a few of these areas. After brushing, vacuuming I backwash and the water is green. I run it till it clears then add more DE. I have increased the flow of the auto chlorinator.
    38,548
    If you see algae, you are not done with the SLAM or need to do it again.
    Post up test results. It is clear that you are not maintaining the FC high enough for your CYA level if algae is growing. And the mention of a chlorinator makes me even more suspect.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    +1
    Unless that auto chlorinator is a stenner or liquidator you are pushing up the CYA. High CYA - too low FC = algae.
    Support the site
