Results 1 to 12 of 12
Thread: Can I really go two sunny days in AZ with no chlorine loss?
    May 2014
    Phoenix, AZ
    34
    On Sunday evening:
    FC 5.5
    CC 0
    PH 7.6
    TA 110
    CH 400
    CYA 50
    Added liquid chlorine to bring FC back up to 8.
    Monday morning:
    FC 8.5
    Tuesday morning:
    FC 8.5
    Hmmm... that seems weird.
    Tuesday evening:
    FC 8.5
    Thought maybe I'm doing the test too fast now that I'm familiar with it. So, re-did the test immediately and came up with 8.0 - within the testing margin of error.
    Is there anything that I could be doing wrong? Is this at all something that would be expected? From everything I've read on the site -- chlorine is a consumable that needs to be replenished daily.
    Are there chlorine fairies?
    25K gal, fiberglass, Hayward 1hp pump, Sta-rite 30" sand filter, Hayward Pool Vac
    38,305
    Re: Can I really go two sunny days in AZ with no chlorine loss?
    Should not be possible without adding chlorine.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I know we say that every pool is different, but not losing any chlorine in AZ over two sunny days is very strange...to the point I would say virtually impossible. A few thoughts:
    1. What are you using to test with?
    2. How old are the reagents?
    3. Consider having someone else perform the test as a check to see how close the results are.
    May 2014
    Phoenix, AZ
    34
    Quote Originally Posted by BoDarville View Post
    A few thoughts:
    I am testing with FAS-DPD chemicals purchased last month
    I went through a 2 week SLAM at the end of May to turn my green pool to sparkly and never saw any unexpected results during all the times I tested. Pool is still beautiful and test results haven't showed anything other than what I would expect for the last 3 weeks.
    I thought I was done with twice a day testing
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Silly question, who doesn't love those... right?
    Are you leaving it covered, or uncovered?
    I would try the OTO test, as a sanity check to see if it indicates considerably higher chlorine or not. It'll turn orange, brown, or have little floating globs suspended in an otherwise clear sample if it does. But I doubt it's that high, worth checking though, in case your sample is partially bleaching out.
    Also, did you run your pump at least 30min prior to testing? This is to circulate the water enough to ensure you don't have any high/low concentrations of Cl.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    May 2014
    Phoenix, AZ
    34
    This morning I made sure that the pump had been running for at least 1/2 hour before testing (I think it usually is... but, made sure).
    FC 8.0
    used ChemTek TruTest Strips
    FC 6.0
    used chlorine test from my Taylor K2005 (don't have an OTO yet)
    FC 5+
    The pool is uncovered.
    For the last 3 weeks, I have been adding somewhere around a quart a day. It seems like the other two tests (however inaccurate they may be) still think I have enough chlorine for today.
    Should I stop on my way home and get an OTO? Or, are my other two "leftover" testing methods sufficient for now?
    Just me and my two golden retrievers here -- so, no chance that anyone else in the household has added chlorine. I asked them... they just smiled and wagged their tails (same answer as for every other question I ask )
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    You don't have a SWG right?
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Butterfly's Avatar
    South Carolina
    10,045
    heh heh
    Do you have any pucks in a floater/canister or anything like that?
    You're done SLAMing when:
    May 2014
    Phoenix, AZ
    34
    Ah... I'm a dummy!
    No SWG. But, I do have some left-over trichlor in my floaters working to raise the CYA.
    They've been in there since I finished my SLAM. I realized over the weekend that my calculation for how much I needed to raise my CYA by 10 had been way off. So, I added a lot more to the floaters. In a total reversal of my thinking - I forgot that they also added chlorine
    Thanks everyone for helping me figure it out!!
    Butterfly's Avatar
    South Carolina
    10,045
    Glad you figured it out!
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Yaayyyy you got it nailed!! Glad the dogs were at least willing.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Butterfly
    Nice call Butterfly!
