Thread: new intex pool filled with well water 1st water test
    Apr 2014
    monroe WI
    11
    filled the pool. Have not added anything or turned on pump yet, still filling have about 1ft to full.
    here are the numbers tested with tf-100
    FC 0
    CC 0
    TC 0
    PH 7.2
    TA 320-330
    CH 500? all water blue at 50 drops
    CYA less than 20
    Water temp 66*F
    should I worry about the TA or CH the pool is a 22x52 ultra frame
    Jeremiah Strese Southwest WI
    22' x 52" Intex AG 11400 gals (I guess)
    2650 intex sand filter TF-100 test kit
    Hopefully adding water by June 24 2014
    Apr 2014
    monroe WI
    11
    Re: new intex pool filled with well water 1st water test
    Bump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    All you need to worry about for now is to get some chlorine in the water - target 3 on poolmath since you have zero CYA. While that's mixing, weigh out enough stabilizer into a sock to get to 40ish and get that started dissolving. At that point, you can let the kids in the chilly water.
    The pH will climb fast with that high TA, so tomorrow you'll probably need to add acid. You won't need to check CYA for a week, because it takes a while to dissolve completely and register on the test.
    Here's what and how to add: http://www.troublefreepool.com/conte...pool-chemicals
    Here's how to use poolmath to know how much to add: http://www.troublefreepool.com/conte...ool-calculator
    This thread is pretty much the same situation you're in: http://www.troublefreepool.com/threa...rst-water-test
