Thread: Hayward pool heater error
    I`m getting the SF or 5F error on my heater. Just replaced the low temp sensor and still has the problem. If I unplug it for a minute or so and plug it back in,it fires up and shuts itself back off with the same code. I have the new high temp sensor and haven`t replaced it yet. Could really use some input. Thanks!
    Re: Hayward pool heater error
    Do I need to order IDXLTER1930?
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Yes the SF is the temp sensor that needs to be replaced and yes IDXLTER1930 is it.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Thanks for the help. Wasted $60 on the wrong sensors. Should have just asked!
    Pool heater is working again!! Thanks ps0303 !!!!!!!!!!!!!!!!
