Thread: Is this used to add chemicals?
    We bought our house with the pool already here. At the bottom of this there is return coming out, which fills up the whole thing and then it drains into the tube which leads out an "eyeball" in the shallow end.
    Is it for putting tablets in? That's the first thing that popped to mind...
    It's dirty! I hadn't been able to get it open since we moved in. I happened to be spraying down everything and shot the hose blast into the eyeball as I was walking around the shallow end and the buildup of pressure popped the top off finally.
    Casey's Avatar
    SW PA
    10,448
    Re: Is this used to add chemicals?
    Hey Rob,
    I'm not sure what it's for but maybe someone else does.
    38,301
    I think that is to put tablets in, not that I would. Any discoloration around where the water enters the pool?
    Aug 2011
    Middle TN
    83
    Are you sure it's not something like an autofill?
    18 x 36 Vinyl Inground, Coverstar Cover, 2 speed Pentair Pump, Hayward 425 Sq Ft Cartridge Filter, Hayward Heat Pump, Prologic PS8, T-15 Salt Cell, 2 Colorlogic LED lights, TF-100 Test Kit
    Jblizzle, no discoloration around the entrance.
    Blueskies21, Swung by a pool supply store for a strainer basket and showed the guy there that pic and that was his guess, but I'd guess no because if I don't fill the pool with the hose, it will go down, and with the flow I feel coming from the bottom of this thing, I can't imagine the level of the pool going down. IE - the same flow from the hose will noticeably raise the level of the pool in several hours.
