Thread: Gas Line Question
    Gas Line Question
    I've got a 200K NG Raypak coming tomorrow. There is already gas line running from the meter to a manual shut off valve (which is capped) from a prior heater. My question is can I use flexible gas line to finish the run between the shut off valve and the heater. Probably only be about 2 feet. Also, does there need to be a rigid (iron) nipple coming directly off the heater if I do actually get to use flexible piping? Thanks for all the help.
    12,000 gal, IG, Fiberglass
    Sand Filter,
    Auto Cover
    Raypak 206A NG
    38,524
    Re: Gas Line Question
    I am not positive, but I think I have read that flex is not allowed by code for that application. Might want to check with your local authority. There should also be a T trap (terminology?) before going into the heater I think.
    Aug 2013
    Maryland
    93
    Not sure that you'll get the flow you need with flex, but I could be wrong. 200k is a fair amount of gas and rigid piping has much less restriction.
    ps0303's Avatar
    Jul 2011
    FL
    3,710
    Ive seen it done but you need to verify your local codes on this. Personally I wouldn't do it.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Here's the final product. No major issues w the Raypak.
    Sand Filter,
    Auto Cover
    Raypak 206A NG
    38,524
    Looks perfect to my limited understanding ... way better than the hack done at the house I bought.
