Thread: Cloudy water after swimming
    Jan 2010
    Randleman,NC
    620
    I'm just bust'd&can't figure out.The past couple year's every time I have people over to swim.Water will get cloudy within the hour of swimming.I've tried increasing clorine&still doesn't work.I check'd water after ther swim today.Now mind'd that I alway's add clorine in the evening's.I decided to check while there were still in water.Test result's.FC 3 CC 0 Alk 70 PH 7.5.CYA 45.I noticed that FC has fell below the min of 4 with my CYA being 45.Like I said I've tried running it higher.But,the problem is I start having a bleach smell.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Donldson's Avatar
    NW Ohio
    2,926
    Re: Cloudy water after swimming
    Since I am using my phone I won't go in to great detail, but if you smell chlorine when you raise your FC that means it is reacting with something. Sounds like a good SLAM is in order as you might have algae just waiting for its chance to explode.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    It's normal to have a drop in FC and even some cloudiness after a lot of swimmers. The other alternative is that you aren't brushing enough and the swimmers disturb all the dust that is clinging to the walls and floor and getting it into suspension, hence the cloudy appearance.
    Jan 2010
    Randleman,NC
    620
    Richard,thank's.I was wondering the samething.Ugg!!!Got start getting out the brush
    Jan 2010
    Randleman,NC
    620
    Just a little update!!!Thank's Richard..You were right..I brush'd good&start'd running DE thru the filter.We are back where we should be.Have about 15 family member's over&water is still clear.Happy 4th to all..
