Thread: Semo
    Jun 2014
    Scott City, MO 63780
    5
    Semo
    I am new to the thread; however, I had been in the backyard pool business for 20 years. It has been a trip from the chlorine feeders through the cartridge and diatomaceous earth filters to the current SWG and sand filter. Great info on this site, answering most all questions concerning pool operation problems, whether equipment or pilot error. I live in Southeast Missouri where we have an overabundance of summer humidity.
    19400 gal vinyl liner, Sta-Rite 1hp pump, Jandy SFTM25 Sand filter, Compupool CPSC24, all set up on timer, Kreepy Krauly vacuum, water solar panels, Taylor FAS-DPD tester, Pentair CYA test kit, DE medium enhance sand filter.
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Semo
    Howdy Semo! Did you put your pool in yourself and pick out all the equipment?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Semo
    Welcome to TFP!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Semo
    Welcome to TFP
    ........"overabundance of summer humidity" Oh, yeah, I heard that!
    You're done SLAMing when:
    Jun 2014
    5
    Re: Semo
    No, I did not install it, but have changed the equipment myself over the years, including installing a stretch cover. It has been a learning experience, but have reached the point where any pool problem is almost nonexistent.
