Results 1 to 14 of 14
Thread: slime/film in the filter
    Aug 2013
    Seaville NJ
    10
    Been battling on and off green stuff at bottom of pool... ordered the special testing kit will be here in a few days. Added 1big jug of bleach yesterday and 2 more today. Every morning however it needs to be vacuumed of the spotty green on the bottom. I also noticed that my light has algae (i think) inside! Thinking it may be the trigger point?
    round 13,500 gal pool
    vinyl
    put in last year. Had bad algae problem last year. You guys helped me clear it up!
    any suggestions while I wait for the testing kit?
    Thanks a ton
    oh and 4 days ago I added one box of borax and two days ago muratic acid (2 cups) to lower ph
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: slime/film in the filter
    How have you been testing last year and this year up until now? Got any test results? How do you normally chlorinate?
    How did you decide how much bleach, borax and MA to use?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    the light can definitely be a harbor for algae. Recommend to take it out of the niche and clean it out real well.
    Divin Dave,
    Aug 2013
    Seaville NJ
    10
    Quote Originally Posted by YippeeSkippy View Post
    Well I guess just using the test strips from the store allowed me to guesstimate...
    this morn I used the little testing kit from the pool store- ph soooo high it was fuchsia and chlorine really high
    I added 2 cups of MA to help lower just now.
    Perhaps the ph is helping the alge to survive. Well at least the levels of chlorine is still high from last night.
    Hows that for no test kit? ugh...
    pool is clear with less green at bottom
    Divin Dave... I have to lower the pool water don't I to do this? TY!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Super high FC reacts with the pH test reagent and makes it read artificially high. So stop playing with pH or when the FC drops to normal, you may find yourself dealing with super low pH.
    Without the proper test kit, you're working blind. It would be like painting a picture wearing a blindfold. You'll get lots of paint on the canvas, but the results will not be pretty and you'll have wasted a lot of paint and ruined the canvas.
    Looking back...on 08-15-2013, 04:48 AM you posted "have to order one of the proper testing kits". It should have arrived by now.
    Get the right test kit. Study the Shock Level And Maintain directions and follow them explicitly. That includes using the right test kit. Then your pool will clear up. This could be the very last time you ever have to clear the swamp.
    The light should have a screw you loosen and then the whole thing tilts up and out and it should have enough cord to allow you to set the light itself on the deck while you scrub out the niche in the wall. It doesn't need to be drained.
    Aug 2013
    Seaville NJ
    10
    Richard guess what arrived today... yes my TF-100!
    thanks for the info on the ph , good stuff! Keep you posted!
    Thanks again
    Aug 2013
    Seaville NJ
    10
    FC 13.5
    No CC's
    13.5 TC
    Ta= 110
    CYA 40
    CH 125
    How does this look? Don't know how to figure out what the levels should be in my 13,500 round 4 ft deep vinyl pool
    Jun 2012
    Rochester, NY
    247
    Quote Originally Posted by cuccismith View Post
    FC 13.5
    No CC's
    13.5 TC
    Ta= 110
    CYA 40
    CH 125
    OK, Good. How does the water look? Did you clean the light out? How do you normally chlorinate your pool? (You said you added liquid, but is that your current normal process?)
    Based on these answers, you may need to SLAM. But, I would wait til the FC drops below 10 to get a pH reading. If you have sun on it today and/or have something growing, you should be below 10 later today.
    Once you get the pH reading, you can use PoolMath at the top of the screen to fill in all your info to see what you need.
    Rick
    Installed June 2012 Aqua Leader 24ft Round AG Influence w/54 inch walls 13,500 gallons
    Cartridge Filter 100SF, 1.5HP
    Aqua Plus Smarte System - In for vacations, BBB all the way.
    Love my PVC Solar Cover Hangers
    Aug 2013
    Seaville NJ
    10
    Thanks! Water looks good I jumped in and ran my foot in the edge between bottom and sides some green began to fog up. I purposely did all over pool, moved steps and found more.
    I usually just add plain bleach. I went to that at the end of last year after fixing a BLACK pool.
    Afraid to do light by self just yet. Wanted to see the numbers first. as that seems like a big deal.
    Fc is the reading with the more simple blue box right?
    Thanks again!
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    FC is the first reading on the FAS-DPD test.
    Aug 2013
    Seaville NJ
    10
    ok if you're still around : )
    I have FC 7.5
    and did ph test and it's also 7.5
    Vacuumed and pool is just a bit cloudy can see bottom just cloudy
    Please pardon the ignorance... I thought we could just use liquid bleach- went to the pool math page and I see various chemical names to plug in.
    I really want to do this correctly. And then I need to research the charts and plug in the goal for the numbers right?
    Richard320's Avatar
    Jan 2010
    18,967
    I have FC 7.5
    Liquid bleach is the preferred choice. You're only juggling one parameter that way. A lengthier explanation is here in Pool School.
    You needn't do a whole lot of research. If you enter you chlorine source and pool surface and tfp down at the bottom of poolmath, it will give suggested ranges. They are not absolutes, however. More explanation of how to use poolmath is here in Pool School.
    Aug 2013
    Seaville NJ
    10
    Ok I got it - I understand the pool math : )
    all making sense now.
    Says I have to add Calcium Chloride so I'll go to hardware and get...
    Do you think I should slam as the algae was there this morn again (lightly bottom of pool)
    FC is 7.5 now
    Richard320's Avatar
    Jan 2010
    18,967
    FC is 7.5 now
    Algae is a sure sign you need the SLAM process.
