Thread: Polaris 480 Pro staining pool?
    May 2014
    Pflugerville, TX
    148
    Is it possible my Polaris 480 is staining my plaster? I have several spots around the pool bottom that looks like something sat there and made a round spot.
    You'd think the Polaris wouldn't have anything that could rust/stain.. but I had it out last week to change an o-ring and let it sit on my decking for a few days and there was a spot right under where the polaris was that stained my deck brown/red (like a rusty screw/nut dribbling rust water out?)...?
    If that's the case how can I fix this.. both the polaris and the stains?
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    Casey's Avatar
    SW PA
    10,453
    Re: Polaris 480 Pro staining pool?
    Welcome mindflux.
    I'm not sure how you would fix it, maybe replace the screw with a stainless steel one? Lets see what other's think of this.
