Thread: Leveling an Intex Pool
    Jun 2014
    Warren, AR
    1
    Please start a new thread if you have questions concerning your pool so that answers intended for you are not confused with answers intended for the author of the original thread. Zea3 Post moved from New member Intex Metal Frame Pool couple of questions about level.
    Does it matter if the frame is level but the ground under the liner is not?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Leveling an Intex Pool
    You can have high or low spots in the floor of the pool as long as the structure is level and well supported. It may make the pool more difficult to keep clean if the floor is not level.
    Love TFP? Become a
    TFP Supporter!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    If it is too out of level, I would imagine the liner would eventually put the legs out of level, too. An inch or less wouldnt hurt. Best to do it right tye first time, then to have to tear it down and relevel after filling.....
    JamesT's Avatar
    Jun 2013
    Little Rock, Arkansas
    48
    Through a bit of trial and error over the years I have found that yes the ground under the liner needs to be level. Leveling the top rail is important also for structural soundness and for looks.
    The water inside the pool will seek its own level and cause a bulge and over time cause the legs on that side to lean. The more out of level the ground is the more the legs will lean.
    An easy set pool (the kind with the blow up ring) if placed on ground that is not level will roll toward the low side. If the ground is very much out of level it can and will collapse.
    The liner inside the frame pool is doing the same thing but the frame is trying to hold it in place. Although quiet sturdy there is just not enough resistance there to keep the liner in place. A few high spots across the bottom wont hurt anything but from side to side needs to be level
    Iím in Little Rock just up the road from you. Hope everything works out.
    8 year old Intex 16 x 48 metal frame - Intex 1600 Pump with 14" sand filter - Intex Old Style SWG (ladder broke and poked huge hole in the side)
    New 18 x 48 Ultra frame Intex - Intex 2650 pump with sand filter - Intex Old Style SWG
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Last year, my piers under the legs sank and made the pool unlevel. This made the frame sink about an inch. That caused the liner to bulge at the bottom and push the legs out. So, yes, IMO the ground needs to be level.
    And hey fellow Arkansans! I'm over here in Russellville!
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Levelling is a necessary evil and most people who've done it manually on here will equate it to a never ending task, me included.... But once you get it right, its so satisfying, and you know you're structurally sound...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
