Thread: SUPER NEWB! Cant seem to get it right .
    Jun 2014
    Chicago, IL
    28
    So last Thursday I decided to open my pool after not opening last year. I bought a brand new cartridge for my filter. I pumped the water off the tarp and took it off. But some of the stuff on the tarp got in pool because it ripped. So I started my shock treatment. Since Thursday I have used 12 gallons of shock. Not all at once. 2 in morning and 2 at night mostly. My pool is 18 feet in diameter by 42 in deep. All of the sudden my pump wasn't sucking in and pushing out good. SO I cleaned the filter and it when back to normal for only like 10 minutes. Now I have removed cartridge and pump works great. Kept cleaning filter over and over and over. My pool was really dirty. Now my pool is super cloudy and I just turned pump off hoping that everything will drop to bottom like it usually does. I only have test strip kit and dual (pH and cl drops kit).
    FCI= 1
    ALK= 180
    PH7.2
    CYA= 40
    drops
    cl=3.0
    ph=7.6
    What should I do? I was hoping everything would drop to bottom and then I can vacuum it with out cartridge and run the inlet house right to a sewer I have in backyard. Do I need new cartridge? I just bought one 5 days ago! Thank you
    Mar 2014
    Las Vegas
    288
    Re: SUPER NEWB! Cant seem to get it right .
    You probably don't need a new cartridge. If it's a small one, it is probably clogging up real fast. Keep cleaning. If you still have the old one, swap filters. Put clean one in, start pump, clean the one taken out, repeat. Without your pool info in your signature no one can give an accurate answer. Without test results from a good test kit, about all we can do is guess.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Jun 2014
    Chicago, IL
    28
    There you go buddy! I ordered a Taylor Complete FAS-DPD Pool Water Test Kit K-2006 today so hopefully it is here soon. Cleaning my filter every ten minutes is to much work. Its not small its like 3 feet tall.
    Mar 2014
    Las Vegas
    288
    With a filter that size clogging so fast, about the only thing I can think of is to put a nylon stocking on your skimmer basket to catch some of the gunk before it gets to the filter and a lot of scooping/shoveling as much gunk out of the pool as you can.
    Jun 2014
    Chicago, IL
    28
    That's the thing though... there really isn't that much going in there that I can see. I will start to put nylon n it. Good advice. I think its all the algea and I need some more shock!
    AG 18' non- SWG pool (6900-7400 gallons), Hayward power -flo lx pump (1.5hp), swim pro cartridge filter model c100(single cart)
