Results 1 to 13 of 13
Thread: Minor scaling above water line
    clw72's Avatar
    Oct 2013
    Fort Worth, TX
    66
    Pool is 6 months old and I have fought high pH and high TA from the beginning. My numbers as of yesterday are:
    FC 5
    pH 7.8
    TA 150
    CH 290
    CYA 35
    Salt 3100
    There is some scaling on the water line tile just above the water line. I believe that's due to the pH and TA being too high for too long. I am in the process of lowering pH and aerating to get the TA down and I have added CYA granules to raise that number. Is there anything else I should be doing?
    Carman
    17K gallon IG pool w/Spa, 400,000 BTU Propane Hayward Heater, StoneScapes finish w/sealed Oklahoma Flagstone coping and tanning ledge, Hayward Aquarite Salt System, 60ft D.E. filter, Hayward Tristar 2 HP 2 speed pump, Polaris 280, Pro Logic PS4 w/freeze guard. New build December 2013. Pool gets full sun.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: Minor scaling above water line
    Your plaster is still relatively new, and pH will continue to rise as it cures. It takes about a year for the process to complete and stop effecting the pH. Use muriatic acid or dry acid to lower pH & TA. Aeration raises pH without effecting TA levels, so that will not help your situation. You don't need to lower TA just for the sake of having a lower test value, once you are able to keep your pH fairly stable.
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    A pumice stone will remove that water line. It will sound awful - fingernails on a chalkbooard X10 - but it doesn't destroy the tile surface the way it sounds like it's doing. It will also lead to sore shoulders and knees. There will also be a lot of pumice grit to vacuum up.
    clw72's Avatar
    Oct 2013
    Fort Worth, TX
    66
    Well that sounds super fun!
    Carman
    clw72's Avatar
    Oct 2013
    Fort Worth, TX
    66
    Quote Originally Posted by zea3 View Post
    So, am I wasting my time aerating? High TA is okay for now? I'm so confused, because I've read other threads that say, lower pH with acid then aerate to raise pH repeating the cycle until TA is within range.
    Carman
    Jul 2009
    Houston, Texas
    9,409
    TA helps regulate pH. If the TA level is causing problems then it should be adjusted, however your pH is going to climb naturally as the plaster continues to cure. Useing acid will lower both pH and TA, you just don't need to aerate to raise the pH back up, it will come up by itself. Once the pH starts to stabilize you won't have to worry about the TA regardless of how high it reads.
    Love TFP? Become a
    TFP Supporter!
    clw72's Avatar
    Oct 2013
    Fort Worth, TX
    66
    Gotcha. Thanks for the explanation.
    Carman
    I have a bit of that calcium build up as well on my new build pool. My PB suggested I mix 50/50 water and muriatic acid in a spray bottle and spay on the tile and then a little scrubbing. It actually worked perfect. Needed to add some acid to lower my PH so did while I was dosing the pool and it basically ate the scaling up without a lot of scrubbing.
    clw72's Avatar
    Oct 2013
    Fort Worth, TX
    66
    Quote Originally Posted by Tresiarth View Post
    Nice! I'll try that this week. Thanks for the tip.
    Carman
    Quote Originally Posted by clw72 View Post
    You will find it works well. Just be sure to use gloves and not lean too close to the tile to avoid splash back. Otherwise I let the acid do the work and avoided much scrubbing. I had one very large one; and just continued to spray let the acid eat it and spray again until it was basically gone. I bought some piece of **** calcium scrubber from Leslie that didn't even make a dent... so that is going back..... Also put your water in the spray bottle first... then add your acid.... following that rule of adding acid to water... not the other way around.
    In Ground 15X27 80 ft perimeter; 3'6 to 5' depth; 9600 gallons; 2 skimmers; 6 returns; Jandy VSP; 2 pool LED lights; 1 spa pool light; pebble tech aqua blue, North Texas build complete April 2014
    clw72's Avatar
    Oct 2013
    Fort Worth, TX
    66
    Gotcha. Thank you so much!! I buy as little as possible from Leslie's. Even when they try to push products on me. I fell for that trap with our previous pool...thank goodness I found this forum when we started building our current pool!! 👍👍
    Carman
    clw72's Avatar
    Oct 2013
    Fort Worth, TX
    66
    The water/acid mix in a spray bottle worked perfectly!!! My water line tile looks brand new. Thank you so much for the tip! 👊
    Carman
    Great!!! I am glad it worked for you!!!😀🏊
    In ground, 15x27, 80 feet perimeter, 3'6 to 5 feet deep, 9,600 gallons, 2 skimmers, 6 returns, Jandy VSP, Jandy DE 60, Jandy LXI, Nature 2 Ozone, 2 pool LED lights, 1 Spa LED light pebble tech aqua blue. Frisco,
    Texas
