Results 1 to 7 of 7
Thread: Large section of sagging liner
    I have about 9 feet of an overlap liner sagging down into my pool. I've seen tips about being able to stretch the liner with hot water or a hair dryer, but I'm worried that this is too big of a gap for those solutions. Is there any other answer to this problem?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Large section of sagging liner
    Hi, welcome to TFP! Do you know what caused the liner to pull away?
    Love TFP? Become a
    TFP Supporter!
    Casey's Avatar
    SW PA
    10,448
    You may need a new one. If there isn't enough there to pull over, you'll need to replace it.
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    511
    IMHO I would get a jhook...easier to install.. I stayed away from overlap because I was terrified of it being pulled out(failing) at some point.
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    Casey's Avatar
    SW PA
    10,448
    The only way it would fail is if the excess was cut off and the liner pulled away and shrunk. There's no reason to fear over lap liners.
    I'm not certain why it pulled away. It was like that when I took the cover off. The water level may have been too low. We also have a harsh winter, I'm not sure how much freeze and thaw would have affected it.
    Casey's Avatar
    SW PA
    10,448
    How much liner is there to pull over the wall and 're clip it using the plastic and the metal stabilizer bars? If you can get it over the wall with excess liner to spare, you're good to go.
