Results 1 to 7 of 7
Thread: What pump should I get?
    Mar 2013
    South Windsor ,CT
    22
    I am looking to replace my 20+ year old pump. Currently 1/2 hp. I have 1 floor drain. 1 skimmer. 2 return lines one has a pool skim. No bells and whistles. Currently run 8hrs a day . Was thinking about http://www.poolsuppliessuperstore.co...mp-1-5-HP.html Seems to b dohenys 1.5.is that overkill? I need it to b 240v . Any good suggestions. Not just looking for cheapest option. Unsure about 2speed . Lower electrical bill not to concerning.
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
    Jandy aquapureIE SWG
    38,246
    Re: What pump should I get?
    If a 1/2HP worked, why would you increase to 1.5HP?
    If you want to stay with a single speed, look for another 1/2HP or 3/4HP ... most can be either voltage.
    Although, I would recommend upgrading to a 2-speed ... look for a 1HP which will be 230V. Like the Superflo.
    Never heard of that brand in your like ... so use at own risk.
    patrick3229's Avatar
    Feb 2012
    258
    Speck Pump has a good 1 HP Variable speed pump for $599 which may be an option for your application.
    38,246
    If they are not worried about the electrical savings, I am not sure I would suggest a $600 VS pump when a $400 2-speed would save nearly as much in electricity ... especially when they are looking at a $220 no name single speed pump.
    Feb 2012
    258
    I see that now..... "Lower electrical bill not to concerning." if that is the case disregard the variable speed pump.
    Mar 2013
    South Windsor ,CT
    22
    It is also outdoors through out the season if that matters
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
    Feb 2012
    258
    Pretty much every pool pump will be outdoor rated so this would not effect the decision process on the pump you choose. If you want to stay with single speed then I would suggest the 1/2 or 3/4 HP Hayward Super Pump and if you wanted to go to a Dual speed pump then the 1 HP Pentair Superflo would be a good option.
