Thread: Light has no power in the socket but at the light....
    Oct 2012
    Houston, TX
    29
    I pulled the light last week, and took it apart, the bulb was broken in half, and i had to remove the base with the old potato trick. Here is where it gets strange (no water in unit). There is power to the unit at the high temperature sensor (thing that looks like a cigarette butt on the left of the bulb socket thats covered in paper), but no power to the base of the bulb socket. Theres power at the light switch and the gfci, so i assume i just need to replace the whole thing???
    Ideas? Suggestions?
    40,000 gallon ig gunite, Pentair Challanger Century Centurion 2.2 HP Pump, FNS 60 DE filter, Polaris 280, Century Centurion 3/4 HP Booster Pump, Attached ig spa - 1HP Centurion pump - Dual non functioning blowers
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Light has no power in the socket but at the light....
    Seems like it's time for a new light. I'd imagine the sensor has failed, and the light isn't repairable.
    It sounds like the thermal overload switch got stuck in the open position.
    Assuming you did your testing correctly, the only real alternative is to replace the entire fixture.
