Thread: Rain
    May 2014
    Monroe, Louisiana
    32
    Rain
    What do you do during a heavy rain?
    My chemistry was perfect yesterday when I did a full test, and the rain started last night. I usually put some chlorine in the evening.
    Is it best to try to keep up with the chemistry through a storm, or just deal with it all afterward?
    NE Louisiana
    25k gallon IG 16x30 vinyl liner pool
    Hayward Super Pump 1.5HP
    Intermatic timer, ~8hr/day
    Sand filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Rain
    Just deal with it afterwards.
    altho, I have been known to go out and backwash some water out when it was rising.....but no thunder and lightening were involved - just some more rain!
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Rain
    What do I do? I try to harvest as much Calcium-free water as I can!
    Unless you get massive amounts of debris or surface runoff in the pool, rain really won't mess things up too bad. A big pool party probably does worse. The pH can get weird, since a lot of times the rain picks up CO2 on the way down, which drives pH down, but a hard pounding also aerates, so pH will go up. If you overflow, you'll lose some CYA. But really, if you have a test kit, once you can get out there afterwards, you can get things fixed in an hour.
    May 2014
    Monroe, Louisiana
    32
    Re: Rain
    My CYA has been on the highish side, so that's a good thing!!
