Thread: Adding Chemicals
    May 2014
    New Caney, Texas 77357
    5
    Adding Chemicals
    When pool water needs to be adjusted is there an order for adding chemicals and how long should you wait before each additional chemical is added. Are you suppose to add one thing at a time.
    In-ground 16x32 Gunite with ceramic tiled waterline. Whisperflo 2hp pump, Pentair 420 cartridge filter, Rainbow Model 320 Automatic Chlorinator, Polaris 280 & Polaris 3/4 hp booster pump, Amerlite 500 watt pool light
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Adding Chemicals
    Ph, then Fc, then whatever else after that. 30 minutes apart will be fine.
    Butterfly's Avatar
    South Carolina
    10,045
    Also, if you need to adjust CH do it last after everything else is balanced.
    You're done SLAMing when:
